Trailers
SWING TONGUE
Ensure the swing tongue is folded fully forward, the pivot pin is installed, and the keeper pin is installed in the bottom of the pivot pin before towing. When folding the swing tongue open or forward to the fully closed position, be sure that the brake hose is not kinked or pinched in any way. A pinched or kinked brake hose will cause the brakes to drag and overheat.
NOTE: Because all pins, fasteners and other components are specially designed, high-strength components, any component re- placement or adjustment of the swing tongue should be performed by your authorized MasterCraft dealer
