Old 11-28-2018, 07:09 PM
Hmbone Hmbone is offline
Boat: 2004 crownline
2011 port ballast timer issue
Iím having an issue with my port side ballast. It will fill but not empty. The pump does not even run when switched to empty. Itís definitely not the pump because I switched the wires coming out of the jabsco timer box and used the kgb knob to empty the port side.
I did check the wires coming from the AI box and Iím getting 12volts out of the jabsco AI when the port switch is on fill, but no voltage when itís on empty. This is a 2011 X25 with BIG screen. I just bought it this September. Iím new to wakeboats, but I have gotten a lot of info from team talk. Any help would be appreciated. Trying not to get frustrated.
Old 11-28-2018, 07:14 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
Did you check the timer in the big screen?
-Aric
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
Old 11-28-2018, 08:35 PM
I went to viper diagnostics ->ballast timer, and it was set to whatever the starboard was set on.
Old 11-28-2018, 08:56 PM
rgardjr1's Avatar
rgardjr1 rgardjr1 is offline
If itís setup like the older versions its probably a bad relay. I had the same problem with mine and I could tap on the box that holds the timers and relays and get it to kick on.
2006 Maristar 200 SS
Old 11-29-2018, 05:19 AM
tr6coug's Avatar
tr6coug tr6coug is offline
Boat: Mastercraft 2007 X2 MCX
Yup, sounds like a bad relay
'07 Navy Blue X2 MCX
http://www.wakeblaster.com/
Old 11-29-2018, 02:41 PM
Is it possible to replace the relay and not replace the entire box? Or do y’all know of someone who does this? I’m 4-5hrs from any MC shop, and it would be a lot easier to send off or if it’s easy I can just replace the relay myself.
Thanks for yalls help.
Old 11-29-2018, 02:50 PM
rgardjr1's Avatar
Originally Posted by Hmbone View Post
Is it possible to replace the relay and not replace the entire box? Or do yíall know of someone who does this? Iím 4-5hrs from any MC shop, and it would be a lot easier to send off or if itís easy I can just replace the relay myself.
Yes you can easily replace the relay. I'm pretty sure the relays in my ballast box were these exact ones:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You should find your ballast breaker control box and take a look at the relays. You can probably source them at your local auto parts store.
