Old 02-15-2019, 05:33 AM
vespa vespa is offline
Boat: Mastercraft X2 2008. vortex 350
Talking After timing the engine and set idle ,engine goes back out of time .
Hi , I did the timing with a timing light after changing the distributor on MCX vortex V8 engine , Mastercraft X2 2008 . Everything is perfect until yo go idle , as soon as you engage the gear , the engine looks out of timing again . If I stop the engine , disconnect the battery and then start , everything goes perfect .
Any feedback Appreciated !!!!
Old 02-15-2019, 05:57 AM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
How did you set timing? I believe you need to put the ECM into timing mode which raises the rpm automatically and holds it while you set timing.
I know on an rtp you can do it my jumpering 2 pins in the odb plug in....not sure on an MCX
Sent from my SM-G920R6 using Tapatalk
2004 Prostar 197, ACME 843
Old 02-15-2019, 11:09 AM
CantRepeat's Avatar
Different computer on the RTP and that 08 so you can't just jump the DLC like the old days.
OP you'll need a scan tool or Diacom software and cable to put the MEFI 5 ecu into diagnostic mode so you can set the timing.
How are you setting the idle? There should be no mechanical changes you can do on that motor to change the idle. It's done in the ecu.
Tim
Old 02-15-2019, 02:58 PM
Yes you are right , To set the timing, the engine must be put into diagnostic mode. The easiest way to do this is take a paper clip and use it as a jumper to jump pins A and B of the data connector on the back of the engine. This connector is in the main wiring harness by itself and has a gray and black cover on it (see bad picture). The pins are marked so it will be easy to know where to put the paper clip. Stick one end of the paper clip in pin A and the other end in pin B. When you start the engine it should idle at 1000 RPMs.
But I still wonder how to do the timing when everything is set.
Old 02-15-2019, 03:04 PM
Can you pls tell me what to do for timing the engine when I manage to set the MEFI 5 eco i to diagnostic mode ?
About setting the idle , what I mean was thrust in idle . Thanks
Old 02-15-2019, 03:23 PM
sand2snow22's Avatar
Boat: Ri257
HV cap? MCX or RTP? In Diacomm, cam angle 705 plus or minus 5 above 1,200 RPM's!
Old 02-15-2019, 04:16 PM
Old 02-16-2019, 10:45 PM
gwozhog's Avatar
gwozhog gwozhog is offline
Boat: Achilles sg124
If that is a current pick you need to either clean or replace your air filter. That thing looks clogged and might be giving you problems.
I once dated a girl in high shcool and her dad told me I would never amount to anything. He was right.
Old 02-16-2019, 11:50 PM
Boat: Ri257
Yes, if they are real dirty they won't stay running at idle..
