Old 12-21-2018, 11:02 PM
6KidSurf's Avatar
6KidSurf 6KidSurf is offline
Boat: 2015 X20
Center Ballast Pump Trips off Unexpectedly
Just as the season was ending for us a few weeks ago, I took the 2015 X20 out and when filling the 3 ballast tanks, the center pump tripped off at 7%. I restarted it and it again tripped/shut off well before it filled. I finale got it filled. Then when I was emptying it, the pump again kept tripping off.
I am being told my pump might have a bad impeller - and that I should have changed those out each year. Doubting this will be a warranty item.
(1) Does anyone have any insights on a pump that trips off unexpectedly?
(2) Does the replacement of impellers make sense? and
(3) is that something that I should have been doing each year?
Thanks for any help and insights anyone can share!
Old 12-22-2018, 07:44 AM
MattsCraft's Avatar
I would start with changing the impellers - It could also be a bad pump. IMO, every year would be overkill, but it is usage dependent - I change mine out after 2 seasons, but again, we don't do more than 50 hours a season.
Also, what are your timers set to for the KGB? Additionally, I have my float sensors disconnected, these are notorious for getting confused/failing - This way my system runs on time alone.
Lastly - long debated here, However - I fill engine running, standing still @ 1200 RPM, empty in gear @ 1200 + to empty - I get 2 seasons plus out of the impellers, & have consistent fill/empty times
Old 12-22-2018, 10:15 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
I put between 40-50 hours on my boat. I can get 3 seasons easily out of my impellers. I pull them out every year when I winterize. I just inspect them then and look for any major flat spots on the tips. If the impeller tips aren't worn no need to change them.
We defy the mafia!
Old 12-23-2018, 09:20 AM
6KidSurf's Avatar
Boat: 2015 X20
Thanks guys for the advice - it's a huge help. And based on the hours on my boat, I am overdue on changing the impellers! Merry Christmas!
