Old 05-23-2019, 02:49 PM
TNstevo TNstevo is offline
Boat: 2003 x2 mcx
Missing clear coat on transom sparkle?
Just went to buff out oxidation on transom on my 09 x45, with the meguirs 105, 205, wool pad etc like I had successfully done in past on older boat. It only got whiter, and after inquiring with dealer learned that the “flake”finish is done differently with clear coat and was told clear coat has been sanded off. What options/quick fixes might be available other than repainting/clear coating which I was coated at around $1000? Thanks in advance!
Old 05-23-2019, 04:40 PM
SS LS1's Avatar
SS LS1 SS LS1 is offline
Boat: '13 X2 Pro Gen2, '98 30th Anniv PS190- SOLD-
Can't think of any quick cheap fixes unfortunately. The "clear coat" should actually just be clear gel coat that is put in the mold first then the flake is sprayed on next. However the clear gel is famous for yellowing out in the sun if left exposed or uncovered which is likely what happened. Typically this happens on exposed transom or horizontal surfaces like metal flake swim platforms.
To clean up the boat to sell the previous owner probably sanded off the yellowed clear gel exposing the flake which is now exposed and damaged requiring big $$ to fix.
I think you are up a creek without a paddle so to speak but would love to hear if anyone know of a way to cheaply fix your problem as it will only get worse.
2013 X2 Pro Pkg, Gen2 Surf
SOLD - 1998 30th Anniversary ProStar 190
Old 05-23-2019, 07:05 PM
Maxirat427's Avatar
Maxirat427 Maxirat427 is offline
Boat: '14 X30 6.2L, '96 SkiRay Tournament
That’s pretty much exactly right. You may be able to find a shop that can tape it off shoot the clear just on the transom and then blend/buff in at the tape line. There will be a noticeable line wherever you decide to break the clear and blend into the factory gel but it will look much better than no clearcoat at all.
There may be better ways to relax than being on a boat...I just haven't found one yet!
Old 05-23-2019, 11:29 PM
Boat: 2003 x2 mcx
Thanks guys, that’s what I was afraid of. I’m considering doing a partial wrap over transom that would match color scheme (not flake) as a temporary @$200 fix to buy time until I invest the grand to foot right, as have several other high dollar ticket items at the moment. Are the wraps bad about leaving residue when taken off? Thanks again.
Old 05-24-2019, 04:12 AM
JagNL JagNL is offline
Boat: 2008 X-45 6.0L LY6
If you aren't afraid to try a little DIY you can buy this clear coat in a (spray) can that many use when fixing yellowed headlights the proper way (permanent, ultra clear fix that last years)/wheels/bumpers etc. This is truly clear coat in a can so you'd need to wear respiratory protection and mask off your swim deck as well as the surrounding area, but if it didn't work out you could sand it back off. Not sure about blending but thought I'd throw it out there as in idea:
https://www.amazon.com/U-S-Chemical-...s%2C158&sr=8-4
Old 05-24-2019, 08:57 AM
Ironhorse Ironhorse is offline
Boat: 2008 Mastercraft X14 w/ LY6
If you can get the flake cleaned up, you may be able to have the transom covered in a clear 3M as a temporary fix.
Old 05-24-2019, 09:30 AM
Maxirat427's Avatar
I use 3m 1080 vinyl. It works great. Never had a residue issue.
Old 05-24-2019, 09:43 AM
MIskiboat MIskiboat is offline
Boat: Prostar
3m paint protection film. Amazon has it.
I use as transom protector, but may work for what you need too...
Old 05-26-2019, 07:22 AM
venetrex's Avatar
venetrex venetrex is offline
Boat: X2
Clear coat
Can someone upload pics of what this looks like. I have a similar problem and considered clear coating mine as well. I am willing to bet it would help a lot.
Old 05-26-2019, 02:08 PM
Thrall's Avatar
Thrall Thrall is offline
Boat: '06 X2 MCX
That's not going to shine it up.
'06 X2 MCX
