  #7321
Old 12-06-2018, 02:16 PM
Double D's Avatar
Double D Double D is offline
Boat: 2008 X14, w/ LY6 400HP w/ 1.22 Ratio Tran
Originally Posted by Footin View Post
Dave, how about a 12v power port (cig lighter)? I have debated removing my stern light port and replacing it with a power port to fill tubes and other floatables from the platform.
Something like this, it would be a fairly flush mount:
https://www.overtons.com/product/det...yABEgKluPD_BwE
Another good thought, but I have a 12V plug about 3' away under the starboard seat.
2008 MasterCraft X14, LY6, 400 HP
1994 MasterCraft ProStar 205 (SOLD)
Old 12-06-2018, 02:20 PM
88 PS190 88 PS190 is offline
I would not remove that stern light post - atleast around here if the DNR/Sheriff pulls you over they make you demonstrate functioning legal navigation lights - so you need that pole - bet you could pick up a spare pole, cut the pole and splice a cigarette lighter onto a cut down light pull and use the same socket for a power source though!
If I had that hole already I would consider just using a cheap through hull bulkhead fitting like used for a bilge pump to close the hole, run that hose down to the bilge and be done with it. Or... add another bilge pump/discharge for ballast.
Old 12-06-2018, 02:29 PM
For daytime use?
Old 12-06-2018, 02:36 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
I have a tower light and a stern light.
OH-IO!
Old 12-14-2018, 11:53 AM
P-hat_in_Cincy's Avatar
P-hat_in_Cincy P-hat_in_Cincy is offline
Boat: MasterCraft Prostar 205V "wakeboard edition", 2004
Originally Posted by carlsonwa View Post
Where did you order that valve from ?
Supplyhouse.com. 1-1/4" hose ID (for '18 XT20).
Sent from my Pixel using Tapatalk
2004 MasterCraft Prostar 205v 'Wakeboard Edition'
Old 12-14-2018, 12:48 PM
Soder's Avatar
Soder Soder is offline
Boat: 2004 X-30 MCX
Lightbulb
I used the same valve on my ‘04 X-30. I’m guessing this is the right size for almost every MasterCraft.
I use it every fall/spring for winterization and “summarization” because my trailer bunks block my intake. More importantly, it’s waaay easier.
I also use it at Lake Powell for decontamination when we pull out. I keep a fitting on board that fits their hot water pressure sprayer.
2004 X-30 5.7L MCX
Old 12-16-2018, 01:46 PM
gwozhog's Avatar
gwozhog gwozhog is offline
Boat: Achilles sg124
Originally Posted by Beerboat23 View Post
Dealer is just wrapping my boat up after this decided to blow up.
That does not look like the original damper plate it was a crappier design with no encapsulated springs. How many hours did you get out of that one?
I once dated a girl in high shcool and her dad told me I would never amount to anything. He was right.
Old 12-22-2018, 10:42 AM
Beerboat23 Beerboat23 is offline
Boat: 2004 x2 mcx 350
Engine has 150hr previous owner cracked the block from a freeze I was told.
2004 x2
Old 12-24-2018, 05:07 PM
Double D's Avatar
Well decided to go with a light pole to act as a flag holder to fill the hole. The power wire was already in the back corner so I had to extend it and now itís already wire to the proper switch. Had to remove the lid to get to the wire.
While at it I moved the shower disconnect into the rear glove box along with the slick binder pump and now the shower can stay connected all the time.
Then started adding that Double D bling...
Now to tackle the heater core.
Old 12-25-2018, 08:19 AM
mike koen's Avatar
Where do you purchase those drink holders ? Mine are cheap black plastic. LIke to do that upgrade.
If she don't shine , she ain't mine
