Old 06-01-2017, 10:58 PM
mgs96ps mgs96ps is offline
Banned
Boat: A
I think I can shed some clarity on this. The replacement carter fuel pump comes with a threaded hose barbed type fitting. If you want to use that...you will need to cut factory rubber hose coming from tank. I did not want to do that. The factory gas line coming from tank has a female crimped thread nut. To make it plug and play you will need a 5/8 18 tread to 06 AN adapter for main fuel line to thread into.
Second...when you remove old pump, take the return thread insert with it. Leave that nipple threaded into the y union and cap it off.
Old 06-02-2017, 06:42 AM
MC FEVER's Avatar
MC FEVER MC FEVER is offline
Boat: 93 Prostar 205 LT1
Originally Posted by mshearin View Post
At about $100 the Carter is a much better option financially but I also realize you get what you pay for.
Is it worth it to get the Indmar pump from Skidom or go with the less expensive alternative?
Thanks in advance for your comments and recommendations!
The original OEM replacement pump (carter as well) was only $100 bucks before it was no longer available. I've got a couple hours and many sets course skiing on a p5000 in my 93 LT1. No problems, runs great.
- I'd rather be SWERVING!
Old 06-18-2017, 12:55 AM
mshearin mshearin is offline
Boat: Mastercraft ProStar 190 1998
mgs96ps do you have a link or suggestion to buy the 5/8 18 thread to 06 AN adapter? I wouldn't know where to begin to source this item.
I'm getting bog at WOT so it's time to replace. I figure if I have to replumb, might as well go with the Carter and pick up a spare and still be half the price of the Indamr. Thanks for all the help!
Old 06-18-2017, 09:25 AM
amazon?
https://www.amazon.com/Speed-SupRex-...d+to+06+an+ada
http://aeroquipperformance.com/c-101...l-fitting.html
Old 06-18-2017, 09:34 AM
Thanks MCFever - P5000 seems the right pump for MPI and p61171 for TBI!
awesome I believe we have the solutions to our prized ladies!
Old 06-18-2017, 12:11 PM
So I've been staring at this for a while; I really appreciate everyones help and patience.
I have the LT1 so do I need the P-5000 or the P-61171? I think I need the P-5000 but in the 2nd post on this thread mikeg205 said the correct part is P-61171. I've looked at the specs on Summit's site and there's no fuel flow specs on P-61171 to compare to the P-5000 so I'm sorta confused.
Mikeg205 you seem to be the most knowledgable about the fuel system, can you confirm I need the P-5000 for the LT1?
Not to be ignorant but what does MPI and TBI mean?
Thanks again for everyone's help, I really appreciate it!
Old 06-18-2017, 12:45 PM
forcel0 forcel0 is offline
Boat: 2009 CSX 220 Saltwater Series
I believe
TBI is throttle body injected meaning fuel is injected into the throttle body like a carburetor.
MPI is multiport injected meaning an injector for each cylinder.
I'll let the experts confirm though
Present
2009 CSX 220 SS
Past
1999 Maristar 210 VRS LTR
Old 06-18-2017, 01:21 PM
go p5000 its rated at 75psi for multi-port fuel injection (MPI - MFI)
Old 06-18-2017, 01:55 PM
Perfect, thanks! P-5000 it is!
Old 06-18-2017, 05:33 PM
waterskibrad waterskibrad is offline
Boat: 1995 LT-1 prostar 190
I can say with experience the P-61171 is only rated at Rated 35 GPH 40 PSI
Works ok on my LT1 tell you really get on it, than you will get a slight bog, but for now I’ll live with it, too lazy to change it out. I’m old, I’m in no hurry to do anything
