Old 06-27-2006, 10:00 AM
sberry3827 sberry3827 is offline
Boat: 1985 SS
Send a message via AIM to sberry3827
Cleaning with SnoBowl
Ok, so I have seen a lot about using SnoBowl to clean the hull. What would be the proper mix for this. I'm scared to use too much. thanks
Old 06-27-2006, 10:39 AM
Lottawatta Lottawatta is offline
Use it full strength. No need to dilute it.
Old 06-27-2006, 10:44 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
I'd be curious to know why a bathroom toilet bowl cleaner would be any better at cleaning fiberglass stains than any other preparation of muriatic, phosphoric, or oxalic acid that's MADE to safely clean gelcoat instead of porcelain, such as Zing.
Probably, it's cheaper than Babe's ... even so, I don't think one would be using enough of the stuff to make the cost difference that big a deal.
'04 MariStar 230VRS/MCX
Old 06-27-2006, 10:50 AM
TMCNo1 TMCNo1 is offline
Boat: Gone
What kind of water requires SnoBowl to clean the hull? Just throw in a Clorox Toilet Bowl Cleaner tablet in the lake or river every so often and start double flushing.
Charter Member Number 1
Quote: 2RLAKE,
Old 06-27-2006, 11:37 AM
SkiDog's Avatar
SkiDog SkiDog is offline
Boat: 07 X2, again!
I use it at 50 - 50, then spray it on, let soak for a few minutes, scrub with SOFT bristle brush, rinse. WEAR PROTECTIVE GLOVES AND EYE PROTECTION!!!!! THIS STUFF STINGS!
Old 06-27-2006, 11:41 AM
Ric's Avatar
Ric Ric is offline
Boat: 2005 Prostar 197 / MCX
admittedly taking the easy route, I use bathroom cleaner for gelcoat stain(scum)
cheap and easy (X14 or tilex)
spray it on and don't mess around wiping it in or rinsing it off as it will streak.
dry her, wax her and you are done.
Originally Posted by TX.X-30 fan
Say yes to cheap beer---- no to ethanol.
Old 06-29-2006, 10:13 PM
JohnnyB's Avatar
JohnnyB JohnnyB is offline
Boat: 2004 Prostar 190
Use it full strength in a tank sprayer (lawn weed killer tank sprayer)...easy on easy off....make sure you get the liquid, not the gel.
2004 Prostar 197, ACME 843
Old 07-09-2006, 12:31 PM
Upper Michigan Prostar190's Avatar
Upper Michigan Prostar190 Upper Michigan Prostar190 is offline
Boat: 1991 mastercraft Prostar 190, 351 w/powerslot. Blue & grey.
Now why didnt anybody else think of that?
Skidog, dont forget to take your Geritol.
Originally Posted by Upper Michigan Prostar190
On a different note: I like LOTS of snort comin' out of the hole.
Old 07-09-2006, 05:47 PM
SkiDog's Avatar
Boat: 07 X2, again!
Cause SOMEBODY put toooo much paper in the _____________ and it won't flush now!
Old 07-09-2006, 06:02 PM
Boat: Gone
Carry the Fake-A-Lake with you and stick your finger in the hose fitting and plundge like there is no tommorrow or set the emergency brake on the boat and sit there WOT, so the prop will clear the clog!
