Old 10-18-2004, 03:57 PM
rasmithaz rasmithaz is offline
Boat: 99 Prostar 205
Gelcoat Cleaning
I am getting close to finishing the mechanical concerns on a boat I bought a few months ago and I'm getting ready to clean this boat up. I have played around a bit with vinegar and water and hand applying rubbing coumpound and wax to try to remove the water spots and faded discoloration below the water line. It hasn't worked, but now I'm going to get real serious about attacking this project. How do I start and how do I finish? I want to make this boat look as nice as some of the boat pictures I've seen posted here. I'm not afraid of work so feel free to give advice and I'll get busy. Thanks.
Old 10-18-2004, 05:57 PM
east tx skier's Avatar
east tx skier east tx skier is online now
Boat: 1998 Ski Nautique
I've never tried it, but I've heard a lot of people who've been pleased with the results they've gotten from snobowl toilet cleaner (you heard right) for the water spots. Others have done well with vinegar and water solutions. Just stay away from anything with bleach in it and you'll do alright. I've always used a very mild soap dilluted heavily in water as my manual recommends.
McGuire's car wax and a random orbit buffer has been highly recommended, although a hand buffing has always worked for me. A polishing compound helps, and if it doesn't, a rubbing compound will probalby do well (just make sure you work your way back up the chain to wax). I've heard people have good results with the 3M products.
Don't use armour all on the seats. Use 303 protectant. A mild soap and water (heavily dilluted) combination will usually take care of your upholstery. I hear the MasterCraft vinyl cleaner will take out the rest.
Finally, when all is said and done, put the cover on the boat, even if it's inside. Keeping the dirt off is the key to keeping it clean. When you take it out of the water. Wipe it down religiously. Wax it about twice per season.
Previous: 1993 Prostar 205
FAQ
Tyler Ski Club
Old 10-18-2004, 06:05 PM
NeilM's Avatar
NeilM NeilM is offline
There's a thread on the MBO site where a 50-50 mix of Hydrogen Peroxide and Lysol Toilet Bowl cleaner is recommended. Lots of positive comments from those who have tried it. (I haven't as of yet).
I've watched the detailers at the dealership spray on a commercial toilet bowl cleaner (high in Muriatic Acid) onto hulls that have literally an inch or more of algae & crud stuck to them - it dissolves in a couple of hours.
I tried a more mild ("Toilet Duck") product after picking up some algae scum on mine this summer -- didn't work well at all -- too much elbow grease... If I end up in that condition again next summer, I'm definitely going to try the 'MBO mix'.
After that, a good bottom wax, fiberglass wax, and 303 on the vinyl and you're in great shape...
2002 MariStar 210 VRS 330hp, Tower, Perfect Pass Stargazer, Bimini, Triple KGB Ballast, 400w Clarion XMD3, Bennett X-14 Wake Plate
Old 10-18-2004, 07:14 PM
MasterCrafting's Avatar
MasterCrafting MasterCrafting is offline
Boat: 1992 Prostar 190-Its red
We had some dark river stains and we couldn't get it off very easy. We went to West Marine and they guy said "this is some strong S**t it should take care of ya" he advised that you be very careful when using it. I would recomend it... but put a bag over your metal parts because it corrodes them almost instantly. what is this mystery solution? On-Off it did the whole boat in 5 mins. Its factory white again!
OIL YOUR TEAK DECK!
92 PS190 - Its red.
Old 10-18-2004, 07:23 PM
Ric's Avatar
Ric Ric is offline
Boat: 2005 Prostar 197 / MCX
I've used bathroom cleaner like x7 and even a lysol brand that worked and yes it is WORK because you must wax afterward. Think of it this way, you've cleaned the surface of the gelcoat so clean that it now needs something to protect the porous surface from crudding up again.
Originally Posted by TX.X-30 fan
Say yes to cheap beer---- no to ethanol.
Old 10-19-2004, 10:03 AM
Thrall's Avatar
Thrall Thrall is online now
Boat: '06 X2 MCX
There are many excellent methods for cleaning up the gel coat, as posted above. The fading, though, is oxidation and will need to be compounded and polished out. There are other threads that explain what is needed to do this.
Old 10-19-2004, 10:34 PM
Thrall... are you cleaning off the same apache lake stuff I am? I think I read everything and this is what I got. This is in addition to the above posts. McGuires no. 49 Heavy duty Oxidation and Scratch remover. 3M Industrial Marine Grade Buffing Compound then seal with 3M Finesse It or McGuires Mirror Glaze. 3M Marine Fiberglass Restorer/Wax then seal with 3M Ultra High Performance Wax. If you have a small scratch you can use 2400 and 3600 micro mesh sandpaper soaked overnight in water. Carpet cleaning looks like Woolite with oxyclean or 409 Spray carpet cleaner. Upholstery protectant 303..Is there a brand name and where do you buy it? Will a 1650 RPM Craftsman electric 6" Polisher do the trick on the rubbing compounds and wax buffing or do I have to increase to a 2500 or above polisher?
Old 10-20-2004, 11:35 AM
You can get the 303 at Overtons.
FAQ
Tyler Ski Club
Old 10-20-2004, 10:40 PM
Tgchrist
If the gelcoat is highly faded definitely go with the Mequires,49. Light fade go with color restorer, 44. Then the 3M finnesse it and 3M high performance wax. I have used a lot of different waxes and the 3M is the best. Good Luck.
Old 10-21-2004, 11:21 AM
captkidd's Avatar
captkidd captkidd is offline
Boat: 1994 MasterCraft ProStar 205
Where do you find the Meguiar's 49?
"Measure your wealth not by the things you have, but by the things for which you would not take money."
1994 MasterCraft ProStar 205, 275hp EFI -- Original Owner
