Old 06-13-2006, 06:36 PM
darule336 darule336 is offline
Boat: mastercraft, 19 skier, 1982, ford 351,
Rear engine mounts 1982 MC S&S
How do you adjust these it looks like there is no nut on the bottom of the i bolt and just one on top. IS the ibolt threaded. IF so, why, that sucks! I am rather confused i need to raise my engine up by 1/2 inch. Can the rubber mounts really compress that much.
With my couplers all lined up to .003 the shaft is touch the fiber glass on the bottom. Probly the reason my Tranny went out.
Help This should be easy
Old 06-14-2006, 08:12 AM
Jorski Jorski is online now
Boat: 1993 190 with LT1
Can't you just shim the rubber mounts with washers?
I would guess that if the mounts won't lift the engine high enough, as they are currently set up (and I assume that this is the stock set up), that they must have broken down and compressed. If this is the case you might want to replace them.
Old 06-15-2006, 05:26 PM
Called skidim losen the nut on top and turn the square bolt. Quite easy.
