Old 06-05-2006, 03:03 PM
dpolen's Avatar
dpolen dpolen is offline
Boat: Med Blue 2012 X2, Illmor 5.7
Send a message via MSN to dpolen
Splined or keyed prop?
Can anybody tell me what type of prop I have on my 1998 225 Maristar...is it keyed or splined? I know its a 4 blade OJ 14x20, but unsure about the prop shaft type. I managed to back into a nice little rock 2nd time out...need to get it fixed and I think it would be a good idea to get a backup prop as well. I know I'll have to get a prop puller as well.
Additionally, 14x20 seems like a big prop...anybody with a similar boat drop down to a 14x18 or 14x16...would love to hear what you thought about the switch? I have the 5.7L Vortec base engine. Most of my boating will be recreational skiing and wakeboarding...nothing too serious.
Doug
Old 06-05-2006, 03:05 PM
jkski jkski is offline
You should have a keyed shaft, as to the best of my knowledge, MC did not go to a splined shaft until 2003. When you get a prop puller make sure you get the right one, that is made to pull a 4 blade prop, as it is different from a 3 blade puller.
Old 06-05-2006, 03:06 PM
rodltg2 rodltg2 is offline
Boat: 2017 PS
Send a message via AIM to rodltg2
do you not have access to the boat?it easy to tell by looking at it//
Old 06-05-2006, 03:07 PM
dpolen's Avatar
I'm not exactly sure what I'm looking for if it were keyed.
Old 06-05-2006, 03:08 PM
88 PS190 88 PS190 is offline
Splines look like machined gear teeth, a key is just a relief cut into the prop and shaft into which a little square metal bit sits.
Its probably keyed, but you could also call ski dim and they'll know for you.
Old 06-05-2006, 03:13 PM
dpolen's Avatar
Thanks! I think I see what you're talking about.
Now if I could just get rid of that big rock at the end of the boat ramp.
Old 06-05-2006, 04:34 PM
Ric's Avatar
Ric Ric is offline
Boat: 2005 Prostar 197 / MCX
I think yours is tapered, not splined.... the only reference I have is that the 197 changed to splined shaft in 05 and I assume vdrives changed at the same time
Originally Posted by TX.X-30 fan
Say yes to cheap beer---- no to ethanol.
Old 06-05-2006, 04:45 PM
Tom023 Tom023 is offline
Boat: 2001 X30 LTR
Ric,
Actually I think the Vdrives changed a little earlier, 2002 or 2003. For some reason I think I remember seeing a 2002 X30 and wished I had the splined shaft, but ICBW.
Old 06-05-2006, 04:49 PM
Ric's Avatar
Ric Ric is offline
Welcome back Tom!! a little TJ here, but the kids and I were idling in a lake that's low with a muddy bottom last month and didnt hit anything hard but got the boat pretty stuck and had to get out and push it a ways..
ever since then, my pristine smooth setup seems to be vibrating a bit at low r's and holeshot.
without checking the "undercarriage", a visual look shows no prop damage... is it more likely that I tweaked the propshaft a bit?
I know I need to get an indicator and look at it but am just wondering of anybody's similar experience.
