Go Back   TeamTalk > General MasterCraft Topics > Tow Vehicles
Old 05-23-2006, 11:42 AM
Diesel's Avatar
Diesel Diesel is offline
Boat: 95 Prostar 205
Tow vehicle squating and Fix
At the end of last season I sold my Duarmax due to the inceasing cost of diesel, poor fuel mileage, and an overheating problem GM cannot seem to fix. As a result we used my wife's Yukon to tow the boat at the end of the season. While I was very impressed with the 5.3's power and the running gear I was not impressed with the load handling ability of the factory rear coil springs. Her truck has a factory tow package and the highest CGVW rating of the Yukon trucks yet I did not feel the springs were up to the task. Here is a pic of it last year and you can see the squating rear end with the boat attached.
Here is the after I fixed the problem for comparison. (details to follow)
05 ProStar 209, Navy Flake, Slate Gray, MCX 1:1
Old 05-23-2006, 11:44 AM
rodltg2 rodltg2 is offline
Boat: 2017 PS
Send a message via AIM to rodltg2
looks like the yukon and boat match well at least..
Old 05-23-2006, 11:47 AM
DooSPX's Avatar
DooSPX DooSPX is offline
details man, details
A.K.A. One of a kind mistake
2011 Best In Show- 1987-2000 class
Trying to keep slalom alive
Need a new prop to fit your needs? Call Eric from OJ PROPS 800-359-9730
Old 05-23-2006, 12:08 PM
Diesel's Avatar
So over the winter I started looking at my options. First I found a helper air bellows mfg by AirLift called the Air Lift 1000. Basically you place these inside your existing coil springs and they expand as preassure is added to help with the load. Here is a pic....
I have seen these used in the past and was not impressed with thier performance or durability so I passed.
Then I decided to look at completely replacing the coil spring with an air spring assembly. After some research I discovered H2 Hummers have an optional air-ride suspension system. This was perfect since the H2 is based on the Yukon platform and shares almost identical suspension components. After a long search on Ebay I scored a brand new pair of Hummer H2 air springs for $100.
Once I got the coils springs out of the truck and looked at the mounting surfaces, it turns out the Hummer air bags are almost a direct replacement for the Yukon/XL coil springs.
The upper coil bucket has a series of cut outs which were designed to hold the Hummer air bag. Here is a pic of the upper coil bucket and the cut out slots.
The Hummer air bag has tabs which just slide into the cutouts and you turn it clockwise unti it locks in place. Here is the bag mounted in the upper coil bucket.
Old 05-23-2006, 12:16 PM
Diesel's Avatar
The factory lower mounting coil bucket (axle side) looks like this.
The Hummer air bags came with a 2.5" centering puck which holds them in place on the lower mount. As a result I had to weld a 14mm nut to axle tube so the centering puck could be bolted over the existing coil bucket. Here is a pic of the welded nut.
Now at this point the bags can be placed over the puck and on to the factory axle coil bucket and you are done with mounting the bags...................unless you want to improve the ride a bit. (details to follow).
Old 05-23-2006, 12:26 PM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
My opinion: tow vehicle squat is a function of frame geometry and bad weight distribution, not inadequate springs. IMHO the better (and cheaper/easier) solution is to improve the frame geometry with a weight distributing hitch. Stiffer rear springs make the vehicle look better, but don't fix the probem that's causing that much squat - bad weight distribution.
IMHO, you could have solved the problem better, safer, and easier with a $200 weight distributing hitch.
'04 MariStar 230VRS/MCX
Old 05-23-2006, 12:28 PM
Diesel's Avatar
With the bags pressured up and mounted to the factory lower coil buckets I was not all that happy with the static height of the bags. Too much piston was showing and I wanted to see a little more extension at ride height. Plus the angle of the factory lower braket put a slight missalignment on the bags wich I also did not like. As a result I built this spacer.
Here it is installed on the truck. It mounts over the factory lower coil bucket and the Hummer locating puck holds everything in place.
Old 05-23-2006, 12:31 PM
Diesel's Avatar
I don't belive there is enough wheel base in the Yukon for the weight distributing hitch to work effectively. I believe the coil springs are just too light. The factory spring rate is around 210 which just cannot handle the extra weight. It was designed to ride well not tow.
Old 05-23-2006, 12:35 PM
G-man's Avatar
G-man G-man is offline
Nice write up Diesel, If I need anything more done to my jeep you might have the solution. When I had a 97 Tahoe I put the firestone airbags in. The problem in SUV's is the ride is built for a car and not towing.
06 AWSA Approved Towboat
Old 05-23-2006, 12:43 PM
Diesel's Avatar
So here is a final picture of the bags installed and pressured up at ride height.
At full compression on the bump stops.
Close to full extension.
