Tow Vehicle
I need a little advice - I just bought my first Mastercraft (1996 Prostar 190) with the single axle MC trailer. I think I got a pretty good deal, but the catch is I live in Michigan and I have to pick it up in Lousiana.
![]() My tow vehilce is a 1998 GMC Jimmy with the 4.3L Vortec. It has the tow package (hitch, tranny cooler, etc.) but I just want to know what everyone thinks about the combo... Does the Jimmy have enough to pull a '96 190? Does anyone use a similar tow vehicle? ![]() Thanks for the Help! |
Should be fine. I pull mine w/ a '95 caprice v8. I have a friend who pulls his 190 w/ a tacoma 4cyl.
David '05 197 |
I think that a Jimmy will be fine. That boat/trailer is well with in the limits of the towing capability.
Not great for regular long trip use but will work for one trip and around home use. My brother picked up my 99 MC SportStar(95-97 Prostar Hull) in FL and towed it to VT with his 4.3 Blazer. The boat is 2400lbs dry and lets say another 800-100 for trailer so your only looking at 3,500 lbs. Just make sure the trailer tires, bearding and brakes are up to the trip. My bro got two flats on the trailer on the trip north because the tires had dry rotted over 5 years. Jamie
Currently Boatless Previous Boats: 99 MasterCraft SportStar CB 98 Moomba Boomerang 310 HP 350 Carb 88 MC PowerSlot 240 HP 351 Carb Black on White |
I appreciate your help here. The trailer reportedly has brand new tires and a new spare so I should be in good shape with that. Does anyone know if these MC trailers have bearing buddies or do they need to be greased internally? What do I need to check for on the brakes? I'm really not firmilliar with these surge brakes...
What about straps? Do most people strap the boat (rear) to the trailer for long distances or no need? |
Should have bearing buddies on their. However, ya' never know. You'll get conflicting opinions about strapping the boat to the trailer. Myself, I think it is a good idea. You can never be to safe.
#7
I wouldn't worry about the truck too much either. They may not be made for every day towing like that, but a trip every now and then won't hurt. I am taking my Tacoma 6 cyl TRD 600 miles down to Dallas this weekend to pick up my newly aquired mastercraft. I never even gave it a second though as to whether the truck would make it. That whole $2.00 per gallon of gas sure hurts though.
Just in case... I am right off I-55 in Northern MS. If you have any problems in that area let me know. I should be back Saturday, I hope. (662)-513-3781. Cody |
#8
I strap my boat down so that a minor accident doesn’t end up with boat on the ground. I have a strap that goes over the back, since the platform would be in the way for the rear toe eyes. The major thing to check on the brakes is the fluid level in the tongue. For such a long trip with a smallish tow vehicle its probably worth having the brakes checked by a pro. You also might consider getting the bearings check to if they haven’t been repacked or used much recently. After the FL to VT trip, I had bearing packed and new rotors/pads put on my trailer for a couple hundred. Should be good for 5 years. Jamie
#9
I remove my swim platform when I tow over the road. This also gives access to the 2 rear eyes (although I don't use them). I will strap the boat down. I throw the strap over the top & wrap/duct tape wash-cloths around the strap where it touches the glass.
Otherwise - like everyone else said... you'll be fine. Be sure the spare has air in it and your jack will work on the trailer if you need it!
If one day you're asked: " How did you spend your time here on Earth?" Will you say: "I kept a crabgrass free lawn" It's time to SKI. ![]() |
#10
Thread Tools | |
Display Modes | |
