Old 04-26-2006, 01:42 PM
tph's Avatar
tph tph is offline
Wiring Ignition Switch '89 PS 190
I'm trying to figure out the correct wiring for this switch in combination with the "kill" switch and the ignition breaker on the dash panel. It appears many hands have already preceded me. (It's a mess)
The Ignition switch has 4 poles BAT IGN ACC ST and the kill switch has two wires.
Currently:
- One wire of the "kill" switch wires goes up to the Tachometer. The other one goes to the IGN pole of the switch.
- The BAT pole is connected to the protected side of the ignition breaker.
- The ST pole is connected to a Yellow/Red stripe wire that goes into the harness.
- The ACC pole is connected to the hot lead on the ammeter.
- There is a dangling wire coming from the unprotected side of the ignition breaker.
Any help in getting this all sorted out would be greatly appreciated.
Thanks.
Old 04-30-2006, 12:01 PM
Laurel_Lake_Skier's Avatar
Laurel_Lake_Skier Laurel_Lake_Skier is offline
Boat: 1996 FlightCraft
Here's a bump.
Are you having problems with ignition/key/kill switch not working?
1996 FlightCraft Barefooter—Merc 200 EFI
1991 ProStar 190—Acme 475, GT40-P heads, Edelbrock Performer intake, Mallory YLM Ignition
(SOLD!)
The world is full of youth—what we need is a fountain of smart!
Old 04-30-2006, 02:49 PM
tph- look on the back of the tach and see if there's an ign post. The tach signal comes from the coil.
Usually it goes:
Battery supply lead (from the boat harness) >ignition breaker>ammeter on the battery lead >ignition switch. You don't want to have any devices unprotected against a short.
IGN output may have another lead to the coil + during cranking
ST lead is OK- that goes to the starter solenoid.
ACC pole >safety switch > gauges >harness going to the coil
The ammeter is on the battery lead so you can see if the alternator is charging the battery and if it's only on the accessory lead, won't show the whole load. If it's on the battery lead, it's reflect the accessory load anyway.
Doug- don't you have the same boat? Little help here?
Old 05-01-2006, 10:35 AM
Kevin 89MC's Avatar
I have the same boat, but the prev owner removed my kill switch, so pics of mine would probably not help. TPH, I can take a few pics of mine if you want though.
Kevin
Old 05-01-2006, 03:45 PM
tph's Avatar
tph tph is offline
Ignition switch help
This board is great! Thanks everyone for the help! Including the bump.
I am going to try to sort it out using Jimn's details, but may ask you for a picture Kevin. Thanks again!
The weather's fantastic..I've got to get this thing in the water!
Old 05-01-2006, 03:47 PM
Install the kill switch in the purple line going to the motor. If the Coast Guard inspects the boat, they'll make you leave until it's connected, probably with a fine.
To revise what I posted before, there will be a lead going to the accessory switches and this goes on the ACC terminal. The purple ignition lead goes to the IGN terminal.
Old 05-01-2006, 04:03 PM
tph's Avatar
tph tph is offline
Thanks! Hopefully, this will be enough info to get it right. Good point about the Coast Guard. I've had an unsuccessful inspection before.
Old 05-01-2006, 04:19 PM
Well, the CG mandated the safety switch in the first place and it's definitely one of the things they would look at.
