Old 04-17-2006, 05:36 PM
wakescene's Avatar
wakescene wakescene is offline
Boat: 2001 Maristar 210VRS, LTR 330HP, ZeroFlex Tower, KGB Ballast, PerfectPass Wakeboard Pro,
My beautification project.
Well after some hefty research and reading I finally came to the conclusion that I needed to wetsand my hull to get a few years of saltwater/sun oxidation off. (yes it has gotten that bad after only 4 years).
I purchased a Makita 9227 polisher and also a pad kit. I choose this one http://www.autogeek.net/bfpk400.html from Autogeek.
I ran thru the following process: wetsand w/1500grit > wetsand w/2000grit > Orange pad w/3M HD rubbing compound > Yellow pad w/3M Cleaner Wax > White pad w/Meguires polishing wax.
After about 5-6 hours I have completed about 12ft of the hull, and discovered some very interesting things during the process.
I found that 2 applications of the rubbing compound helpd to get some really stubborn areas fresh again w/o having to wetsand a 2nd time.
I found that slow -N-steady is the way to go. The speed at which you run the polisher is crucial to each step and speed-to-pad is probably a science I will never learn 100% but I found specific speeds that seems to work better than others.
I found there is no concealed area to practice on, so less is sometimes more.
Do small sections 4-5ft. Then complete all steps in this area before moving on. If you have to leave the job, at least you will have completed everything up to that point.
I know some of this is common sense but I have never done this process before. Compounding/Waxing sure, but the process I explained earlier, no. I hope to eventually provide a play-by-play of the entire project. I'll start snapping some picks to show before/after results as well as what speeds worked for me as well as pads and so on.
KG
Old 04-17-2006, 05:50 PM
Sodar's Avatar
Sodar Sodar is online now
Boat: '07 ProStar 197 w/ MCX
Has the cleaner wax been enough to take the swirls out from the Heavy Duty Compound? When I did my old outboard a few years ago, I chose to follow the compound with 3M Finesse-It, followed by the cleaner wax. It would have been much easier though if I could have eliminated that step!!
-Cameron
2007 ProStar 197
1996 ProStar 190
Old 04-18-2006, 12:14 AM
wakescene's Avatar
Sodar,
No I haven't had an issue with the swirl marks. I think their are several things that help ward off the swirl marks.
The buffer. I picked up a Makita 9227L. This thing rocks! I have never had a professional unit like this, but of course price in some situations does dictate quality. Controllable speed with a little dial rigth at your thumb was a new thing. It's amazing how well it holds speed regardless of the amount of pressure you place on it. There were a few times I put my whole 180lbs into it and it never slowed. It also has a slow startup feature to that if you are making contact with something it does not kick into full speed right away.
The pads. This was the first time I have ever used pads like this. I think the pads are AWESOME. They are smooth and soft, and have a large surface area that helps spread things out. No small concentrated areas.
Wetsanding. It flattens out the surface so the pad doesn't see and high/low spots.
Speed. I am fairly certain that speed is the largest factor. I used a slow speed with the compound (750-800rpm), medium speed with the cleaner wax(maybe 1300-1400rpm) and a med-hi speed with the final polish(2000rpm). The polisher only goes to 300rpm so I didn't want to push it.
Movement. Of course the most important thing with a job like this is to never let the polisher stand still.
Each of the speeds though were funny. Slow with the compound is a fight. You fight the polisher every step. As the speed increases the fight gets less, but the risk increases. I did learn a little. I tried to polish around the lettering and burned some of the lettering. I can fix it but it just goes to show.
I am happy so far with the results, I also only have 1/4 of the job done.
Old 04-18-2006, 12:19 AM
Leroy
Wakescene; You are on to something about the sanding! If you are willing I think you have the making of a great FAQ.
Old 04-18-2006, 01:36 PM
wakescene's Avatar
Leroy,
Your correct. I am thinking about doing something like that. Actually it's evolving on it's own and could be a great resource. I did a lot of research before starting this. The only problem was that there was good info on wetsanding, polishing, oxidation etc, but none that I found at least really narrowed down all of it in one hefty document and how to go about things for our particular situation. I will be interesting to see how everything turns out.
Old 04-19-2006, 04:13 PM
Kevin 89MC's Avatar
Wakescene, great documentation. Can't wait to see pics. My '89 patiently awaits some TLC from this neglectful owner.
Good luck and keep sharing your progress.
Old 04-30-2006, 11:34 PM
wakescene's Avatar
So I finished the boat this weekend, but my arms are a little tired so I am gonna rest and post some pics tomorrow. She does look very good though and I took a lot of pics to help create some good documentation.
KG
Old 05-06-2006, 10:38 AM
Bert's Avatar
Bert Bert is offline
Boat: Prostar 190 and X2
KG
Waiting for those pictures
Old 05-10-2006, 01:45 PM
wakescene's Avatar
finally found some time so I'll be working on the write-up this week. Sorry for the delay folks.
Old 05-18-2006, 08:43 PM
wakescene's Avatar
Well I finished writing everything up, and adding the pictures. Please let me know what you think and if I should improve on anything.
Sorry again for the delay.
Kevin
