Old 11-30-2017, 12:46 AM
CamaroMan77 CamaroMan77 is offline
Boat: 1974 Searay 233hp 351W
68 betram velvet drive (71c?) stuck in neutral - wont shift
Hi there.. got a problem with a velvet drive - its in neutral and wont budge.. ideas? Fluid is pink (see pic) suggesting water contamination..
This is the port motor - standard rotation i believe
Saved from hell by Christ.
Old 11-30-2017, 05:56 AM
CantRepeat's Avatar
How long has the boat been sitting with the water in the trans?
Tim
Old 11-30-2017, 01:39 PM
judging by the smell of the gas - over 5 years.. maybe 10- stbd runs fine and drives - small leak from the stuffing box which I will repack..
This is the port side - no drips but doesnt shift.. I can pump out the fluid and refill with atf 3 and see if it will free up..
Old 11-30-2017, 02:21 PM
CantRepeat's Avatar
Is there a data tag on it?
I see a gear reduction on so I believe that is a C72.
Here is the manual for it.
http://www.marineryachts.com/borg_manual.pdf
Here is wouter's rebuild thread of a C71. I believe the shift valve assembly on both are close to the same so you should be able to use that thread to get yours out and cleaned.
http://www.mastercraft.com/teamtalk/...ad.php?t=53874
Tim
Old 11-30-2017, 07:42 PM
88 PS190 88 PS190 is offline
Does the shift arm not move?
Old 11-30-2017, 10:19 PM
nope - shift arm totally stuck.. The detent bracket seems to have lost its grip - the bracket still looks real good.. I guess the lever sticking out of the unit has been worn down.
Managed to clean up the paint today and snapped a pic:
Seems this is a 72c as I suspected. What about alignment? The motor rests on the mounts on this - do I support the motor with something temporary like blocks of wood and a jack?
I did find wouters post last night and saved all the pages - there are some working units on ebay for around 450 incl shipping - so will see whether to roll the dice or pull this one out..
Old 11-30-2017, 10:24 PM
to add, I did spray pb blaster inside and removed the shift solenoid on the other side (switch with wires) - and ran motor for a few seconds to see if fresh ATF might free it up but no luck - shift rod stiff as a rock..
After reading this thread here it seems the cooler is bad -
velvet-drive-transmission-problems
Ill have to remove that first and see what can be done -
Old 12-14-2017, 03:17 PM
I use a pair of hydraulic bottlejacks below the exhaust manifolds and just gradually lift with the front engine mounts loose.
