Old 11-16-2017, 05:13 PM
Cody2662 Cody2662 is offline
Boat: 1997 Mastercraft 205, Chevy V8
Throttle lever
I just purchased a 1997 prostar 205 about a month ago. One of the things I didnít notice on my test drive was that the whole throttle lever assembly pulls away about an inch. Not being any kind of mechanic does anyone know where there is a snap ring or something that I am missing? I canít seem to find a breakdown of it.
Old 11-16-2017, 06:28 PM
there should be an allen set screw at base of the lever
Old 12-15-2017, 03:22 AM
MDB1056 MDB1056 is offline
Boat: 1983 Starts & Stripes Powerslot, 92 Hydrodyne Comp
The allen screw is just for the lever itself. The play you have needs to be tightened from behind to draw the lever back into the housing. Should be a simple couple of screws (3 tops) right there on the front of the plate and then just drop it down from under the side panel , turn it on it's side and I'm guessing you can tighten something there to close that gap and pull it back into the housing, then just put it back in place. My boats are older than your (92 and 83) but I've dropped my controls down for adjustments and lube many times, including just tonight!
