Old 03-25-2006, 01:21 PM
jmts2000
how to remove platform on 89 prostar
I have an 89 Prostar 190 with a broken swim platform bracket. Do I need to remove flooring under gas tank to remove nuts that might be on the inside or can I simply unbolt it from outside the boat? I hope they have inserts and I won't need to take up floor panels.
Thanks, Jeff
Old 03-25-2006, 03:02 PM
TMCNo1 TMCNo1 is offline
Boat: Gone
Thanks, Jeff
We have a '89 PS 190!
YOU DO NOT HAVE TO DO ANYTHING ON THE INSIDE!
Just take out the four bolts and remove bracket or both brackets, as there are THREADED backing plates in the the fiberglass inside placed during layup of the glass and resin, there are no nuts to remove from the inside. When you reinstall the bracket or brackets apply a SMALL amount of silicone if you want around the bolt holes to seal the bolt holes. I assume you do not have the removable brackets, in which a base block is bolted to the transom with 4 bolts and stay permanently attached to the transom and then the platform brackets bolt to the base plate with 2 big bolts, therefore making them the "Optional Removable Swim Platform Brackets" .........................Any more questions, just ask!
Charter Member Number 1
Quote: 2RLAKE,
Old 03-25-2006, 03:04 PM
jmts2000
Thanks for your help!
Old 03-25-2006, 07:35 PM
Boat: Gone
Your welcome, as someone said once somewhere on here, I am here to serve and swerve!
Old 07-10-2016, 08:50 PM
Boobaychap Boobaychap is offline
Boat: Maristar 215 SS, 2007, 5.7L
TMCNo1 ,
I have the same question on a 2007 Maristar 215 SS. Hoping the answer is the same.
Can I just unscrew the five transom bracket bolts from the outside and replace the bracket?
Thanks, Bob
