Old 03-07-2006, 06:00 PM
X-45's Avatar
X-45 X-45 is offline
Boat: Mastercraft, X-45, 2005, MCX 350,
NewGlass2 “fiberglass restoration”
"New Glass 2 is not a wax and does not require polishing or buffing. One quart will restore a 32’ to 40’ Yacht, Boat or Recreational Vehicle.
Following an easy scrub with a mild abrasive cleaner and a thorough rinse with fresh water, New Glass 2 will be absorbed into the Fiberglass Gel Coat by simply wiping on multiple thin coats. A strong chemical bond forms that restores faded colors and provides long lasting protection with a new shine."
Saw it in WaterCraft World Mag. AnyBody ever use this stuff.
My First Hyper Link
If it ain't broke.......screw with it till it is!
Old 03-07-2006, 06:05 PM
erkoehler's Avatar
$40 a bottle....I'll stick with the 303 and carnuba wax
www.boathouseh2o.com
Old 03-08-2006, 11:01 AM
h2oskirs
Stay away from that stuff. I used it on an old boat to bring back the shine. The stuff eventually started to flake off, it is almost like a clear coat film over the gelcoat. Stick with buffing using verying degrees of rubbing compounds, 3M has a good line of products from course coumpound to finishing liquid wax. I then use paste wax to finish.
Comments in another post about Tre-Wax are bang on. That stuff lasts all season.
Old 03-08-2006, 11:06 AM
Sodar's Avatar
Sodar Sodar is offline
Boat: '07 ProStar 197 w/ MCX
You hit both points perfectly! Vertiglass looks great for a little while, but then flakes and needs to be color sanded to remove it. If your gelcoat is in really bad shape, take it to a detail shop and have wetsanded and buffed, then keep it waxed and it will last much longer than this product. Tre-wax is the best too!
-Cameron
2007 ProStar 197
1996 ProStar 190
