Old 02-24-2006, 11:37 AM
DLewis DLewis is offline
Boat: 95 Maristar
Steering wheel removal
I have a 95' Maristar that I need to remove the steering wheel from. I removed the nut and washer from the hub, but the wheel only slides about 1/2" before it stops. Do I need to use a wheel puller or should it come straght off?
Old 02-24-2006, 11:44 AM
east tx skier's Avatar
Boat: 1998 Ski Nautique
I've done it once ona prostar and after taking the nut and washer off the hub, I recall the wheel coming off pretty easily. But my memory could be failing me.
Previous: 1993 Prostar 205
FAQ
Be kind. Have fun.
Old 02-24-2006, 06:26 PM
Boat: 95 Maristar
It has a tilt wheel and I hate to reef on it and damage the helm or the tilt mechanism.
Thanks for your response...maybe I will 'encourage' it with a little more force.
Old 02-24-2006, 06:41 PM
M-Funf's Avatar
M-Funf M-Funf is offline
Boat: 1976 Mastercraft Stars & Stripes 351W
It should come off pretty easy...
Just remember to disconnect the airbag before you monkey with it
M-Funf (a.k.a. Jeff)
Our '76 Stars & Stripes
Canis meus id comedit
Old 02-24-2006, 10:49 PM
tph's Avatar
tph tph is offline
I had a similar experience recently and finally ended up using a puller.
Old 02-25-2006, 01:06 AM
Workin' 4 Toys's Avatar
YES, ONLY DO IT WITH A PULLER....!!!!
Old 02-26-2006, 11:47 AM
Boat: 95 Maristar
Thanks for replys. (After disconnecting the air bag - thanks M-Funf!) I worked it back and forth and it came off. I didn't realize all the pieces that need to come off to get the wheel/steering gear off. However, I found out that the tilt mounting screws had come loose. Once I reinstall it, the tilt will have a much more positive feel.
Thanks.
