  #31
Old 02-20-2006, 09:17 PM
brianaw26's Avatar
brianaw26 brianaw26 is offline
Boat: 1
ive wonderd the same thing myself about the windshield
1981 Mastercraft Stars and Stripes
351 - Powerslot
Photos
Old 02-20-2006, 10:54 PM
John 3:16-18
Old 02-21-2006, 11:00 AM
Brn85ss Brn85ss is offline
I also have the two piece brackets on my 85'.Two aluminum blocks bolt to the transom with four bolts each.The brackets are attached to the blocks with two bolts each.If you only take your platform off acouple times a year this set up is ideal,it's very sturdy but only takes a minute to remove.My 85 is the only S&S I have ever seen with these brackets,they came with the boat when when it was bought new.Mine are off the boat right now and are on the way to the powder coater.
Old 02-21-2006, 11:19 AM
Tom Wortham's Avatar
Tom Wortham Tom Wortham is offline
Boat: MasterCraft, 19 FT, 1986 S&S, 351 Ford
Please post some pics when you get them back. Curious. Tom
Old 02-21-2006, 07:51 PM
dichdoc dichdoc is offline
Boat: 1984 Stars and Stripes powerslot
Yesterday I ordered Fiberglass and Epoxy from Raka and Rub Rail from West Marine. Today I removed the second platform bracket, the rub rail, and the decals. I've figured out a way to save all that money for new decals... I'm pioneering the new look of blue on blue! It will be interesting to see how well this buffs out with the precision auto kit. BRN85ss are you doing a "two coat" powder coating? Heres a pic with the rub rail and decals gone.
Old 02-21-2006, 08:01 PM
Anyone able to tell me about the stickers? The round one was on both sides the letters and numbers on the passenger side only. Wondering if the gel coat will buff out enough or if I'll have to have some kind of replacement made.
Old 02-21-2006, 08:27 PM
Farmer Ted's Avatar
Farmer Ted Farmer Ted is offline
Boat: 1998 Prostar 190
Gus Campbell Watersports in Monroe Louisiana has a bunch of those round stickers in his display case.
318-388-1259 I think they're $20 a peice
Old 02-21-2006, 08:48 PM
SKI*MC's Avatar
SKI*MC SKI*MC is offline
Boat: MasterCraft, Stars and Stripes, 1983, 351 W.
Send a message via AIM to SKI*MC Send a message via MSN to SKI*MC
Check out Rambo Marine, they have everything there.
www.rambomarine.com
You don't have to buy a lake to own it~MasterCraft
Old 02-22-2006, 02:02 PM
furevo's Avatar
furevo furevo is offline
Boat: MC, S&S, 83
Well, peer pressure is a *****! It's -20 today My sled was in 300 pieces and we have a five week old baby. Put the sled back together and the baby was napping so what the hell, lets tear the boat apart! Took two hours to strip her down. I believe it was original carpet (tucked up high on the sides,between hull and foam). I only pulled back the one side before I ran out of time. The Fiberglass floor on the sides of the motor has "bubbled" and pulled away from the foam underneath. There's probably four bubbles around one foot in diameter where you could push it down 1/4". Can anyone point me to a thread or tell me how to fix it? The carpet is laid under the angle iron that supports the motor. Will I need to pull all the lag bolts and raise the motor to lay carpet under again? I read a thread on rub rail replacement where it was stated to drill the rivets and replace with bolts and nuts. How do you access the nuts I seem to have foam everywhere under the rail. I'll post pics tomorrow Travis
I believe those 'bubbles' are where the flooring has delaminated from the stringers. My easy fix was reattaching the floor to the stingers w/ countersunk stainless steel screws. I snapped a stringline, predrilled the holes, dripped epoxy in the holes to bond between stringer and floor, then screwed about every 2-3 inches. The screws sort of dimple the floor & I 'floated' epoxy around each dimple to seal and conceal the screws. It made it really solid. If you search this issue, there are very helpful measurements from someone who tore his floor apart.
Don't pull the angle iron to remove the old carpet. Cut the carpet to the mount. I used indoor/outdoor carpet from Lowe's. JRandol and Mag Red detailed their install and Sporty was a great help, too.
Old 02-22-2006, 08:49 PM
Removed windshield and dash today. Windshield was held down with two screws and about 12 machine screws. Has anyone had luck powder coating the windshield frame? Can you reuse the rubber? What should I use to replace the sticky black foam where it meets the gel coat? I spoke with Larry at Raka the other day and we formulated a plan for my floor. I'm going to cut the delaminated area out clean it all up replace the foam with new and reuse the floor sections, epoxy them back to the stringers and add a few screws. Then using 10 oz tape redo all the seams and I'm going to cover the Foam holes as well as I feel that is a place where water can get in. Thanks to everyone for your ongoing help! TB
