Old 02-18-2006, 07:39 PM
dichdoc dichdoc is offline
Boat: 1984 Stars and Stripes powerslot
Looking for:
Carpet, what weight and where to buy?
rub rail, Wanted Aluminum with black insert dealer?
Fiberglass and Epoxy, what type of cloth for floor and supplier?
Old 02-19-2006, 12:33 PM
tph's Avatar
tph tph is offline
Originally Posted by dichdoc
Looking for:
Taco Marine manufactures the rub rail and insert.
Old 02-19-2006, 02:05 PM
88 PS190 88 PS190 is offline
Carpet is kind of a personal preference, are you going for factory style? or a heavier weight better carpet? Could help to look at a new boat w/ different carpet options. See what you like.
Old 02-19-2006, 07:05 PM
ski_king's Avatar
ski_king ski_king is offline
Looking for:
Looks like style 5 of this to me.
http://www.westmarine.com/webapp/wcs.../10001/618/0/0
Price is around $70, but itmsut be shipped by motor freight which can be big $$. Do you have a local West Marine?
STARS AND STRIPES FOREVER
Old 02-19-2006, 07:08 PM
ski_king's Avatar
Here are the inserts.
Old 02-20-2006, 11:15 AM
Made pretty good progress yesterday. Removed all the carpet, cut hole in floor to "look" at bubble. It is similiar to other post on the subject. 3 rows of three holes aproximately 2 inches each covered in a layer of thin fiberglass tape. Foam got wet and degraded or froze and popped the 1/8" fiberglass floor loose from the black "W's". Looked like I had a layer of Glueish stuff troweled on with a notched trowel? My thought is to cut out the two area on either side of the motor (18" x72") where its bad and clean it up and reglass. Should I remove all the foam as long as I'm there and put new in? any thoughts? TB
Old 02-20-2006, 11:27 AM
Yesterday I also got two small surprises. 1:Learned I have a big fuel filter on passenger side of tank, will work at getting it apart and cleaning. 2: I had "access" covers installed in the floor under the tank. They were sealed down completely. I had to unscrew and pry them off they were stuck to the foam insulation. Someone had "repaired" the swim platform previously. They used 1/4" stainless bolts with nylocks no washers or backing plates. It LEAKED the foam was wet the transom appears to be in good shape still. The top nuts were just above the floor and had been epoxied in. My thoughts on repair was to use a stainless backer plate with 5/16" bolts welded. Stick the bolts out the holes as studs, epoxy and glass the inside. Bolt the bracket back on with cap nuts so it looks pretty. do you see any problems with the stud method or should I bolt from the outside in? TB
Old 02-20-2006, 12:50 PM
tph's Avatar
tph tph is offline
It might be a good time to consider changing over to removeable brackets.
Old 02-20-2006, 12:56 PM
X-45's Avatar
X-45 X-45 is offline
Boat: Mastercraft, X-45, 2005, MCX 350,
I second that motion!!
Old 02-20-2006, 01:53 PM
Show me some pics! Every thread I search talks about all these great pictures that no longer exist. I like the idea of removable for more room in garage but the rattle thing has me leary. Wow I'm up to 18 posts when do I officially loose my Lurker status? I'm thinking of quiting my job to try and catch EastTexas skier!TB
