Old 09-16-2004, 10:22 AM
crdickey crdickey is offline
Boat: 2003 PS-197 - X7
Oil pressure gauge problems
My gauge frequently pegs above 80 psi, even at idle.
With a hand held direct mount it reads normal, 40 @ idle and 70 @ running speed.
'03 PS-197
Preditor motor
51 hours
The dealer has replaced;
The sending unit
The MMDC computer
The gauge
Installed a better ground wire
Any ideas?
Old 08-18-2010, 05:16 PM
morkinbc morkinbc is offline
Boat: 2002 maristar 230vrs
Thumbs down guages
I am having the same trouble.I have replaced sending unitI also have no amp gauge.My check engine light is on and the engine is in limp mode.I have ordered mmdc box.I hope this cures my problem.
Cheers
Mork
Old 09-10-2010, 11:31 PM
BrianB36's Avatar
BrianB36 BrianB36 is offline
Boat: mastercraft s&s 1981 302 powerslot
any sending unit I've come across works off of ground as sensor by-metal is heated the ground strengthens an oil descending unit works opposite if oil gauge stays maxed out may have ambient ground trouble meaning any after market eletronics installed they may have taped into the wrong ground
