Old 02-06-2006, 03:43 PM
Foiler's Avatar
Foiler Foiler is offline
Boat: 93 Prostar LT-1
My first Boat
I'll start by saying I own a MC now but I bought my first boat in 1986 a 15 1/2 Ranger with a 90 hp Mec. I thought I'd like fishing but it wasn't long until the fishing rods stayed home and the skis were in the locker.
I sold that boat to my cousin where it has sat since 1998. His girl friend (this week) likes to fish so we're going to see if it will run. I took the spark plugs out and there is still oil on the threads. I turned the motor over by hand so the rings aren't rusted and froze up. If seen this before where rings rust and attach themselfs to the cylinders. I took the one of the carb bowls off and there was no gas or residue from gas in it.
Everything so far looks good, does anyone know of anything else that I should do or check before we put some fresh gas in and try to start it.
I must say it was good to see the old boat again, it would easily pull me up with for a slalom run...sure brought back some good memories.
Old 02-06-2006, 03:50 PM
jayderwin1's Avatar
jayderwin1 jayderwin1 is offline
Boat: MasterCraft, ProStar 190, 1986, 351.
check the lower unit oil.
Old 02-06-2006, 04:11 PM
bradamerry bradamerry is offline
Boat: 93' Barefoot 200
Very true... I would change it just to be safe.. I change the lower unit oil every two years.
Swaha Lodge Lake Greeson Akansas..... www.swahacabins.com
Old 02-06-2006, 04:25 PM
Workin' 4 Toys's Avatar
On the subject of the carbs. Why no fuel? Was it drained or run dry? And the rings shouldn't be an issue if it was fogged.
If the fuel system was run dry, you should look over the lines, to make sure they aren't cracked or dryrotted. And look for leaks when it first starts even if you didn't find anything obvious. Look close including around the carbs. Dry carbs could make for leaky seals.
Old 02-06-2006, 05:08 PM
Foiler's Avatar
I'll check the lower unit oil...Thanks
The motor wasn't fogged, and the carbs (3) weren't emptied. I don't know where the gas went unless it evaporated. I know on an outboard you have to prime the motor with the sqeeze ball primer. I'm not sure if that has anything to do with no gas being in them or not. Also the motor was stored at a pretty good angle on the trailer with the motor support.
Old 02-06-2006, 08:02 PM
John 3:16-18
Old 02-06-2006, 08:04 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
If not, Sporty will take her.
Old 02-07-2006, 12:59 AM
Foiler's Avatar
[quote=Sporty]Check to see if he know she's going fishing with you? /QUOTE]
She is a pretty girl with long bond hair, she cleans and cooks the fish she catches...kind of unusual.
Old 02-07-2006, 02:50 PM
[quote=Foiler]
Let's see some pictures......... And I don't need to see the boat....
Old 02-07-2006, 04:18 PM
TonyB's Avatar
TonyB TonyB is offline
Boat: 1991 Prostar 190 Powerslot
[quote=Foiler]
TTIUWP*
*This Thread Is Useless Without Pictures
