Old 08-09-2014, 04:14 PM
Longdrive's Avatar
Longdrive Longdrive is offline
Boat: 2000 Prostar 205
Lame Stereo Questions
Hi guys, getting ready to start my stereo build and I'm on a budget looking for confirmation that what I'm trying to do will work.
I currently have a clarion M502 HU and 4 full range speakers run off the HU power. I'd like to add a PPI P900.4 amp for the full range speakers and a PPI P600.2 bridged to power a 10" sub in a sealed box under the helm. I only have 2 sets of RCA outs on the HU; Will this be an issue? The 900.4 is a 4 channel amp so I assume will take all of my avail RCA's. Can someone who knows better school me on the proper way to wire so I won't introduce any noise, add load to my electrical system, or damage my equipment?
Appreciate it!
Old 08-09-2014, 05:26 PM
Jeff d Jeff d is offline
Boat: 2000 230 VRS
Your head unit doesn't have a dedicated set of sub RCAs so you have a few options. The 600.2 will have an RCA output. Feed it first with your rear pair then jump over to the 4 channel amp. You could then just put it in 2 ch mode (i.e. Amplify the rear signal to all 4 speaker outputs) and be done but you will have no fade control (front to rear).
You could run a separate RCA cable from the "front" pair on your head unit to the 4 channel amp and put it in 4 channel mode. This will give you some fade control but if you fade to the front your sub will drop out. You'll be able to fade to the rear without impacting your sub.
If you want full control then buy an equalizer and mount it under your head unit. Connect one pair and then it will "split" it up into front, rear and sub outputs. It will also give you distinct control right there with knobs which is nice. This is the route I would go. Clarion has one that's like $50 with 7 volt preamps and a good reputation. This is the way I would go.
It can be found elsewhere for less but these guys have the best pictures:
http://www.sonicelectronix.com/item_...on-EQS746.html
Old 08-09-2014, 05:29 PM
Boat: 2000 230 VRS
Oh and on noise: put in a ground block for the amps and ground every audio component there. Reroute the head unit's ground there, your equalizer and of course both amps.
Old 08-12-2014, 07:34 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
You can actually run all 4 speakers and a sub off that 900.4 depending on what speakers and sub combination you are planning. You lose a little fading features but it's simple and easily done.
For the two amp solution with only two RCA outputs there are a couple different ways to set them up with y splitters depending on your goal if you want sub adjustability and zone control between the 4 speakers
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
Old 08-12-2014, 07:39 PM
JimN JimN is online now
It would be better to call it 'distribution block' since these are also used for the power cable connections. It would also make it easier to find.
That being the case, using one power cable and ground cable for the whole system is the best way to make sure everything is on the same circuit.
Old 08-16-2014, 12:23 AM
dvsone79's Avatar
dvsone79 dvsone79 is offline
Boat: '99 205v
Just get the PPI 900.5 and you've got 4 channels plus a dedicated sub channel.
