Old 08-05-2014, 01:48 PM
spievy79 spievy79 is offline
Boat: Ski Supreme, Sierra SS,1987, 351W 240hp
And on a side note the crack was so corroded when we discovered it, it appears it may have been that way for a while. I never found a trace of water in the oil either when emptying it. The PO obviously didn't winterize it correctly.
Old 08-05-2014, 02:41 PM
Originally Posted by spievy79 View Post
We ended up making a channel and welding it at my buddy's machine shop. No damage to the cylinders it appears. I'll run it and seehow long it lasts. I figure I'm in the same boat either way needing a new block, but maybe I can finish out the summer with any luck and rebuild over the winter. Anyone see any reason to not do that please advise.
Just make sure you have an anchor and a tow rope so the pontoon can tow you home....
Old 08-05-2014, 03:09 PM
Ha ha, will do!
Old 08-05-2014, 03:30 PM
Boat: No Boat
Did you pre heat the cast iron before welding?
Tim
Old 08-05-2014, 03:35 PM
We attempted to with a torch but we do not know what temp we got it up to. After reading some lit on welding iron it is pretty clear we didn't do it correctly, my main question is: running it and if it fails will I cause any other damage to parts I will want to swap over once I buy a new block, ie: heads, intake, etc?
Old 08-05-2014, 08:33 PM
JB Weld? was wondering if that was going to come up ...
If it's external, it can work, especially if the crack is small. Not an ideal fix, but it can work.
Old 08-06-2014, 01:31 PM
The crack is internal, its about 2" long along the water jacket.
Old 08-12-2014, 09:31 PM
Well, got everything back together and surprisingly the weld held. I pulled off the intake to check it after getting milky oil. Turns out of the head gaskets was leaking at a water jacket. I ended up replacing both head gaskets and put everything back together. I drained the oil then left the drain open and poured a quart of fresh oil down there just to try and get more crappy oil out. I changed the filter and put in the new oil. When I tried to crank it over it was slow. It almost fired a few times but its cranking really slow. I tried two different good batteries with no luck and pulled all the plugs and cranked to get any other water out. Any ideas on this one? Mind you, this is just a band aid situation for the remainder of the season, I'll be getting a new short block over the winter. Just giving it a try for a few extra weeks of possible boating.
Old 08-12-2014, 10:03 PM
1redTA's Avatar
1redTA 1redTA is offline
welding cast iron is tricky, I've done it in the past on vises and whatnot but didn't trust the process enough on an engine. find a 351 W block at a pull a part yard, have it hot tanked, throw your parts in it after glaze braking the bore
1981 MasterCraft
19' Skier 351W PowerSlot
Old 08-12-2014, 10:22 PM
The weld is actually holding thus far. I'm struggling with it cranking over slowly after putting it all back together, after having water in the oil from a bad head gasket.
