Old 07-24-2014, 09:56 PM
mcole80 mcole80 is offline
Boat: MasterCraft X-15 2010 MCX
Engine Noise 2010 X15 MCX
Guys I have attached a video with a noise that I can't identify what it is nor where it could be coming from. Any help would be appreciated.
Old 07-24-2014, 10:00 PM
MC25's Avatar
MC25 MC25 is online now
Boat: 2016 X30, 85 S&S
nothing is attached sir
-Aric
LONE STAR MASTERBASH 2018
Details released eventually
2016 X30-Wetsounds galore
2017 Misty Harbor Tri-Toon
1985 S&S- For Sale
Old 07-25-2014, 12:07 AM
Sorry Guys, here is the video and noise. I could really use some help. The dealer replaced my fault fuel pump, did some maintenance, replaced transmission fluid(oil), oil change, all impellers and when I got the boat back, this noise along with another, which turned out to be the muffler and a gasket but not sure which one, still trying to figure this out.
If anyone has any idea on this noise, it would be appreciated, it is 2 hour drive for me to get the boat back and forth to dealer.
Thank you
Old 07-25-2014, 12:26 AM
CiscoStu's Avatar
CiscoStu CiscoStu is offline
Boat: 2006 X-30, MCX
Is the boat in the water in that vid? It sort of sounds like there's air in the water pump or somewhere in a hose? Did you try revving it up a little?
Old 07-25-2014, 05:37 AM
Boat: No Boat
To me, it sounds like a bearing going bad in either the water pump of the alternator.
Tim
Old 07-25-2014, 10:45 AM
boat is in the water and transmission is engaged and moving like 3 miles per hour.
Old 07-25-2014, 10:54 AM
Boat: No Boat
Does it make the noise when at idle and in neutral?
Tim
Old 07-25-2014, 11:09 AM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
What Cant said.^^^ Does it disappear as the motor revs higher? So the other chirping noise, you posted was fixed and it was the exhaust or gasket? Did they show you what the issue was or tell you what was causing the noise?
Old 07-25-2014, 12:08 PM
I am pretty sure it is making it in neutral and engaged. This is a 2010 X15 with MCX, 297 hours. The boat ran flawless for 285 hours. My fuel Pump went out at 285, had it replaced, I took to authorized MasterCraft dealer, 2 hours away, he replaced all impellers, pump and ballast, changed transmission oil and oil change, spark plugs and a few other things. Since this, my muffler has gone out or the gasket, and this noise continues. I am trying to find a better mechanic at the lake where I keep my boat.
If it makes noise at idle and when engaged what would that lead you to believe?
Thanks for responding
Old 07-25-2014, 12:12 PM
I specifically told them to give me the old mufflers, he originally told me it was the muffler, I had to order the muffler as they told me it would take possible 30 days. when the muffler was removed, he told me I needed a new gasket and they replaced both but still told me it was the muffler not the gasket making the knocking noise. To be honest, I am not sure what to believe but the knocking noise is gone but the chirping or the noise in this post is still there and I know it is not normal. Each time they called me they said the boat was water tested and all is good but this noise should not be there. thanks for responding.
