Old 07-14-2014, 04:00 PM
Thetripinme Thetripinme is offline
Boat: 2002 XStar
Calibrate perfect pass
Trying to dial my perfect pass on a 2002 xstar. Speed on pp is not calibrated to my speed. When I'm at 11.5 on the boat pp says I'm going 5. I tried to calibrate the speedo on the boat but that jacked everything up. I'm pretty sure my speedo is correct now how do I get the pp up to speed. And can I gun the boat while pp is on and it will stop at my speed on this yr?
02' XSTAR
'07 F350
Old 07-14-2014, 04:21 PM
John 3:16-18
Old 07-14-2014, 05:01 PM
bturner2's Avatar
bturner2 bturner2 is offline
Unless you have StarGazer, PP speed comes from the paddlewheel sensor located in the hull of the boat. Typically your speedo is getting it's signal from this same sensor. If so the two should not be so far off and you'll need to determine which one is off. By the description in your post it would appear to be the PP. This would lead me to believe the PP control module is either set up wrong or bad.
Put a call into PP and they'll walk you through figuring out what is wrong and how to correct your problem. If you do get into a situation of replacing the control module Ski It Again usually has several used ones from people that have upgraded to SG or if you have the cash upgrade to SG as the control module will get replaced in the upgrade process and will eliminate the need for a paddlewheel sensor altogether.
