Old 07-14-2014, 01:30 PM
G-Star's Avatar
G-Star G-Star is offline
Boat: 2002 X-Star, LTR
Originally Posted by Jerseydave View Post
I had the same problem a few years back. I replaced my impellers from black to green, no more problems with popping breakers or pump not running. If you don't have green impellers yet get them first and try it. Black are too stiff and sometimes the pump won't spin.
Apparently orange is the new green?
http://www.wakemakers.com/johnson-ul...-impeller.html
2002 X-Star w/ LTR
Old 07-14-2014, 02:38 PM
WakeWise's Avatar
WakeWise WakeWise is offline
Boat: MasterCraft X-30 2014, MasterCraft X-10 2004, Correct Craft SV211 2004, Centurian T-5 2001
And more expensive then the Green ones.
Old 07-14-2014, 05:19 PM
andersonmc andersonmc is offline
Boat: 2001 X star
Ordered 2 green impellers today from Wakemakers. Now I just need to figure out how to rewire pump when I flip it over.
Old 07-14-2014, 05:30 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
You don't need to rewire it, loosen the head and spin it 180 degrees.
OH-IO!
Old 07-14-2014, 05:31 PM
Footin's Avatar
What's the difference between the green and orange beside a few bucks.
OH-IO!
Old 07-14-2014, 05:37 PM
Mastercraft13's Avatar
Boat: 2013 X-10 6.0
I would guess more neoprene vs rubber.
Old 07-14-2014, 05:52 PM
Boat: No Boat
If you don't have room to rotate the pump head you can just switch the two main wires at the switch.
In the wiring schematic, first post in this thread, you can see the primary wires, blue and yellow, would need to be swapped at the ballast pump switch by the helm.
http://www.mastercraft.com/teamtalk/...ad.php?t=40934
Each pump switch would have different colored primary wires.
Tim
Old 07-14-2014, 06:39 PM
Boat: 2001 X star
Can I still rewire my pump even know I Have a separate empty pump? I don't have my Jabco set up to reverse right now.
Old 07-14-2014, 08:25 PM
Boat: 2001 X star
Ended up just switching the wires at the pump. Wakemakers said since I didn't have the pump set up for reverse I couldn't change wires at switch.
Old 07-14-2014, 10:21 PM
swatguy's Avatar
swatguy swatguy is offline
Boat: Nautique
You don't even have to take your pump apart. All you do is pop your plate off on the rocker switch, pop your switch box off the wall or dash, rotate the switch box 180 degrees , reinstall the switch box and then the rocker plate VIOLA pump flow is now reversed.
Or you can do as mentioned and flip the brass head on the pump 180.
So are you saying you have two impellar style pumps for each bag? Are you then saying each pump only has a on or off switch not a 3 position rocker switch, That would be very strange and double the cost for no reason to whomever installed that system. Makes zero sense
CURRENT: 2008 SANTE 210
2000 Mastercraft Xstar
2003, Ski Centurion Cyclone
88 2001 Nautique
