Old 07-07-2014, 10:32 AM
soacj's Avatar
soacj soacj is offline
Boat: Current: '03 X2 w/ MCX. Former: '91 Prostar
Ignition Control Module hot
While working on my '03 X2 w/ MCX this weekend, I noticed the Ignition Control Module (IC) mounted in the base of the distributor generates a lot of heat. I've removed and cleaned the module ,and applied some dielectric grease to the heat sink (need to get some actual thermal paste).
I'm surprised at the amount of heat transferred the "floor" of the distributor where the IC module mounts. It's hot enough after running for a bit to be uncomfortable to the touch.
Think it might be indicative of a problem, or normal?
Old 08-01-2014, 12:03 AM
jprcrprv2 jprcrprv2 is offline
Boat: 2004 X2 350 mcx
It is normal for them to get hot. However I would not run your motor with out actual thermal paste for any extended period of time. Dielectric grease will not transfer heat away from the module into the distributor base which acts as a heat sink, and can cause the module to fail prematurely.
