Old 06-30-2014, 03:20 PM
CarolinaMastercraft CarolinaMastercraft is offline
Boat: 2005 VRS 210
Wiring Connection for fuel pump problem
Was out on my 2005 Maristar 210 on Saturday when the boat died under power. After doing some thinking it had power but wouldn't turn over - or would and sputter. Eventually traced the issue to the fuel pump. The pump itself is fine however a wire from the boat side going into the plastic connector to the pump was coming loose. We held it together and got back to the dock. In the mean time it got hot from poor connection and seems to have damaged the plug. Does anyone have a part number for this? Only had the boat 2 months so I'm not sure if this is factory or not. Any help would be appreciated - My first thought was to just reset the wire into the plastic connector but with it discolored I'm not sure about that. The yellow is fixed to the fuel pump while the black I'm holding is movable and the side where the wire is loose. Thanks for any help
Old 06-30-2014, 03:24 PM
last picture blurry - how is it damaged?
Old 06-30-2014, 03:30 PM
Boat: 2005 VRS 210
The metal inside seems to be discolored and looks like it's melted a bit of the plastic. Will try another picture. I would think I can reset the wire but I'm going out of town and figured that if the part was damaged I could order a new one and have it when I return. Electrical parts and possible damage tend to worry me
Old 06-30-2014, 03:44 PM
Boat: 2005 VRS 210
Here is a better picture
Old 07-01-2014, 09:31 AM
Maristarmax's Avatar
Maristarmax Maristarmax is offline
Boat: 2001 Maristar 210 VRS, LTR 330 HP
I had the same thing happen to my 01 Maristar with the 330 HP LTR engine. I had to replace the fuel pump to fix the yellow connector side. The connector on the harness side is an easy fix. The connector matches a GM IAC motor. I ordered the connector online from Autozone, it comes with wire pigtails already installed in the new connector. I cut the old connector off and soldered the new pigtails to the wires. I think I looked up the IAC connector for a 98 Chevy 1500 C/K truck with a 5.7 engine. Worked great, no problems since.
Maristarmax
2001 MasterCraft MariStar 210 VRS
5.7 330 HP LTR
X-10 Tower, Fly High Ballast
Old 07-09-2014, 05:20 PM
agua4fun's Avatar
agua4fun agua4fun is offline
Boat: Prostar 190 Sammy Duvall & 230VRS
See my post #363 on the thread below:
http://www.mastercraft.com/teamtalk/...=25783&page=37
BWD Part# PT302 - 6" pigtail found at the local auto parts store that works great.
Or Mastercraft harness 508436
Old 07-10-2014, 12:55 PM
Retoxtony's Avatar
Retoxtony Retoxtony is offline
Boat: 2007 Tige RZ2, previously 99 MC205
Had the same problem on my 205 with the LTR. I know the previous owner of my boat chased that problem for a while and threw a pile of parts at it but never replaced the last 6 inches of wiring and the connector that were the problem. You might be able to use a small pick or screwdriver and a pliers to adjust the metal parts that actually make contact with the pins in the yellow end. I did that and it worked till i got the new part.
Old 07-10-2014, 02:26 PM
BallBushing's Avatar
BallBushing BallBushing is offline
Boat: 1999 Maristar 210 VRS
Same problem here '99 210 VRS. Used my daughters hair tie for a year to keep the connection together. Finally bought the harness from Rambo Marine p/n 508436. $31.30 + $13.95 shipping in July 2012. BTW the green wire is no longer used, believe it used to be connected near the gas cap but actually caused, rather than prevented fires.
