Old 06-26-2014, 03:30 PM
Anorth09 Anorth09 is offline
Boat: 1994 Mastercraft Prostar 190 with LT1 Black Hull
After all this work i found possible the worse thing any of us could find.... a cracked block!!! Yes i winterized it! Ran 6 gallons of RV antifreeze through it while it was running. Drained everything I could but i thought the cold we got in Ohio just froze the anitfreeze. When i tore down the engine the heads cooling ports were extreamly clogged. This being a reverse cooling motor very little of the antifreeze go to the block. I learn my lesson on this next year i will be pulling the Knock sensor after running antifreeze through the engine. This will allow the engine to be stored dry. So it was time to get the engine out and find a block.Name:  IMG_1943 - Copy - Copy.jpg
The previous owner rigged a fuel pump it was bouncing around (all new fuel lines and new pump mounted by the gas tank to fix this)
Name:  IMG_1957 - Copy.jpg
All stripped down ready to come out!
Towing it over to a buddies to lift the engine and trans out!!
Yes its nice knowing farmers!
HUSTLE MOTORSPORTS
1994 PROSTAR 190 LT1
Its painted and I dont care if you dont like it!
Old 06-26-2014, 03:34 PM
Originally Posted by ProTour X9 View Post
Green and black is the new teal and pink.
I liked the old look but I am not one to leave anything alone!
HUSTLE MOTORSPORTS
Old 06-26-2014, 03:54 PM
Ended up driving an hour an 1 1/2 to pick up a block that i could build. What i thought could be honed ended up needing to go .030 over. So i had to buy pistons to have the shop press on for me. I got the block back from being hot tanked and honed and started the assembly!!
Name:  IMG_1982 - Copy.jpg
Tear down of my crack block started
New parts started rolling in!
Name:  IMG_1991 - Copy.jpg
Shopwas a wreck from being so busy and so many parts.
Name:  IMG_1994 - Copy.jpg
Name:  IMG_1996 - Copy - Copy - Copy.jpg
Bare block back from hot tank and boring!
Name:  IMG_2108 - Copy - Copy.jpg
Got the rings on the pistons and pistons fir into the block. New cam bearings installed and rollers in place.
Name:  IMG_2141 - Copy.jpg
HUSTLE MOTORSPORTS
Old 06-27-2014, 10:09 AM
Finally got the heads back from the machine shop! They were hot tanked to clean all the build up in the coolant passages, then resurfaced, valve job and new valve springs. 830 hours was enough to wear out a set of valve springs.
Got the heads torqued down with new bolts.
Got the rockers and pushrods in and adjusted. Thought it would be harder then it was. I have done a Honda Civic valve adjustment but never this far in depth.
Name:  IMG_2145 - Copy - Copy - Copy.jpg
Got my new water pump in (LT-1 pump off of a corvette) They have one extra line off the pump that you can cap off. So worth the money you save over a marine one! Also new thermostats installed!
Name:  IMG_2149 - Copy (2).jpg
HUSTLE MOTORSPORTS
Old 06-27-2014, 10:17 AM
Double D's Avatar
Double D Double D is offline
Love the added touch of the green accents on the engine. Go big or go home, that's my motto!!
1994 MasterCraft ProStar 205
275 HP 350 Chevy Indmar
Monster Tower & PerfectPass
Old 06-27-2014, 10:22 AM
sorry to read about the cracked block - awesome job on the rebuild
Old 06-27-2014, 10:31 AM
The big day for me was getting it in and running! No help from a tractor this time just had an old engine hoist... Tractor is the way to go but have to work with what you can get. The good thing about these boats is how fast they come apart and how easy they are to work on.
At first i thought i was going to end up buying manifolds due to the threads being rusted on the drain and one plug would not go back in. I went to a local machine shop to see what they could do for me before dropping even more money on this project. The owner said he had a tap that would work if he could find it.... half hour later we found it!!! But due to how busy he was he let me borrowthe tap to do the repair myself! Got the tap home in within a half hour both manifolds fixed! Afters some grinding and fresh paint good as new
After getting the engine in i decided to replace all the hoses. I wa not about to reuse 20 year old hoses. Got the new hoses installed and new fuel system installed and fired it up! It runs!!! Till i found an oil leak from the rear main seal. So i bought a better one and pulled the transmission and installed a new one next day start it up still leaks. Now i was starting to doubt myself but i gave it another try out comes the transmission again.... This time i pulled the oil pan put a new oil pan gasket and rear main housing gasket on just to be sure.
HUSTLE MOTORSPORTS
Old 06-27-2014, 10:37 AM
Its taken a lot of late nights! The positive is that its a completely new boat!
HUSTLE MOTORSPORTS
Old 06-27-2014, 10:57 AM
That the only way to do it! I order a wake tower and speaker 3 months ago and it still has not arrive!! I cant wait to get the tower on!
HUSTLE MOTORSPORTS
Old 06-27-2014, 11:02 AM
This is the tower i ordered but with a Bimini. From what i have read its either a love or hate it. I do want to add more fiberglass on the inside of the boat before mounting it!
HUSTLE MOTORSPORTS
