Old 06-19-2014, 03:29 PM
Jayhawk's Avatar
Jayhawk Jayhawk is offline
Boat: 2001 X-Star
Dock lines?
I'll be putting the boat (205v) in a slip at Tablerock for a week. I've never used a slip before and need help deciding what lines I will need. Length and how many? Stopped by the dealer and they only stock 10' dock lines. Unsure if this is what I need. If I need longer lines, where would I get them?
Also, do you cover your boats at night when left in a slip?
Old 06-19-2014, 03:31 PM
Some nice lines available here.
http://minneapolis.craigslist.org/hn...527049190.html
Old 06-19-2014, 03:34 PM
Morety's Avatar
Morety Morety is offline
Boat: 2016 X23; 2015 X20; 2014 X10; 2013 MB 21
Get four of the 10' dock lines, tie the boat from each corner to the dock, and make each rope tight enough that the boat can't hit either side of the slip. As long as the slip isn't too wide, 10' dock lines should be plenty. Tie up one side first with enough slack to let the boat float in the middle of the slip, then tie up the other side. The ropes don't have to be completely tight, but make it where the boat can't float to and rub one side at night.
Cover is up to you. Can't hurt to cover it and have fewer bugs and dew to clean up in the morning.
Old 06-19-2014, 04:06 PM
Jayhawk's Avatar
Boat: 2001 X-Star
Thanks, guys. For some reason, I thought I read somewhere you'd need 20-25' lines.
Thanks for the link, Peter. Those look like great lines, but if I can get away with 10 footers, I'll grab some at the dealer.
Old 06-19-2014, 04:22 PM
don't forget the big bubble wrap - wrap boat every night - sleep well
Old 06-19-2014, 04:28 PM
Jayhawk's Avatar
Boat: 2001 X-Star
Ha Ha...I do sleep well having her tucked away in the garage every night. First trip to Tablerock, though, so we are excited.
Old 06-19-2014, 04:48 PM
Thomas21's Avatar
Thomas21 Thomas21 is offline
Boat: 2000 Mastercraft Xstar
I was about to ask the same question. Im taking the family for the first time to Smith Lake in AL. in July.
Old 06-19-2014, 04:49 PM
OHIOPRO205's Avatar
OHIOPRO205 OHIOPRO205 is offline
Boat: 1994 PROSTAR 205
We tie up in a slip every summer at Dale Hollow Lake. I have 3 ropes made up with Brass clips on one end. I tie the boat up as said so no matter which way the boat moves it cannot hit the dock. 1 on each rear corner and 1 in the front. It works great. After it is all tied up all we have to do is unsnap and go. When we get back we snap back in and done. Everyone in the boat knows what is going on and it goes really smooth. I don't have cleats on my 205 so the the 2 loops in the rear and the main trailer ing loop in the front is what I use. Also make it easy to cover at night with nothing in the way.
Old 06-19-2014, 04:50 PM
GoneBoatN's Avatar
Boat: 2010 X-15 w/MCX
If I have a slip that has cleats on the dock on both sides (my preference), I use spring lines on both sides, if possible. Doing this keeps the boat from moving both forward/back and side/side with just four lines. Line length will depend upon the location of the cleats. This allows the boat to rock and pitch independent of the dock but keeps the boat 100% from rubbing against the dock if done correctly. I still put out fenders just in case.
My suggestion is to have lines that are a few feet longer than you boat. I've not regretted having longer lines. I keep two sets - one short set for short duration tie-ups for convenience and one long set just for as I talk about above.
Another effective method if you have an outside slip (I dislike), is to use spring lines combined with breast lines. But then fenders are imperative.
See http://en.wikipedia.org/wiki/Mooring_(watercraft) for a picture of breast vs spring lines.
I just use my "trailerable" cover for overnight mooring.
Old 06-19-2014, 05:19 PM
mzimme's Avatar
mzimme mzimme is offline
Boat: 2006 20' Vdrive
Where you going on Table Rock? When you pick your slip (if you get to), pick one on the side of the dock that will block waves, and also as far in (away from the ends) as possible. Gets you a lot of protection that way so your boat isn't taking a beating.
Whenever I rent a slip for any amount of time, I tie my lines around the dock posts permanently for the week, and just slide the loop end through my cleat when I come tie up. Takes less time and you tie once for the week and all is good. Then I just leave my lines attached to the dock for the day, and when I pull back up after the day out I just grab my already tied line and slide it through my cleat.
Enjoy... Table Rock is an amazing lake. Couple TTers on that lake also!
-Mike
