Old 07-15-2014, 02:41 PM
TallSkinnyGuy TallSkinnyGuy is offline
Boat: 1997 Prostar 190
Here is another place that has it:
http://www.marineexhaustmanifolds.co...-and-parts.htm
Old 09-08-2014, 04:57 PM
BarefootWt's Avatar
BarefootWt BarefootWt is offline
Boat: 1995 Pro Star w/LT1
Send a message via AIM to BarefootWt
Alternate Fuel Pump - Owners Manual Specs
I have a 95 LT1 and have been looking for a replacement fuel pump. My Owners Manual says my LT-1 requires 30-45 PSI. If the P60987 goes up to 35 PSI - seems like this should work just fine until the inlet screen gets clogged
For $32 probably worth a try. Maybe the high-pressure P60962 is for those who never do preventive maintenance
Old 09-09-2014, 12:54 PM
BarefootWt's Avatar
Talked with Carter Pumps technical support - they say the P60987 is rated 40-57 PSI/40-65 gall/hour (too strong for carbs) and the P60962 is rated 60-120 PSI/44-63 gall/hour. Given the LT-1 specification in the owners manual says required pressure is 30-45 PSI, it would seem to me that both pumps "should work" just fine; but I don't claim to be an expert just working with the data? Thoughts?
Old 09-09-2014, 01:56 PM
That spec should make it work just fine $32 at rock auto - order it up!
Old 09-09-2014, 01:57 PM
Wow... when I called before the tech could not give me specs... lol awesome find... awesome info.
Old 09-09-2014, 02:09 PM
BarefootWt's Avatar
Cool - so now I have two pumps on order with expedite on the $32. When I get my awesome machine running again I will follow up on this thread to let you know the results. If it works, I am ordering a spare, or two :-)
Old 09-09-2014, 02:13 PM
I ran a napa 3003 filter just before pump to keep inlet clean... filter on right has about 50 hours on it..
Old 09-09-2014, 02:53 PM
BarefootWt's Avatar
I like this idea. It appears as though the PSI loss would be minimal, if any, by adding this filter in-line between the tank and pump as it looks to be a direct, low resistance pass through (one thread says you can blow through the filter with no resistance). My fuel pump inlet screen did have about a 40% debris blockage when I looked at it. I will pick one up!
Old 09-09-2014, 03:00 PM
I like it because I don't want to be messing with those brass fittings...one improper turn and time for new fittings.. I use to clamps and always check for leaks... never had one... and no loss is power.. plus I don't have to replace the other filter as often - I may change the big can filter after next season since I change it last in 2012 when I added the see thru in line filter.
Old 06-21-2017, 08:48 AM
lake weir skier lake weir skier is offline
Boat: 1994 MasterCraft ProStar 190, 350 TBI, 1:1
It's not my issue personally since I don't have an LT-1, but when I mentioned your post to a Carter technical support tech recently, he said they quote specs on static pressure for pumps and that it's important to distinguish between static and working pressure. If the owner's manual spec is a working pressure and the spec pressure range you were quoted by Carter for their pump is static pressure, this may be an apples and oranges comparison.
1994 ProStar 190, 350 TBI, 1:1
