Old 06-16-2014, 01:36 PM
JasonCarroll JasonCarroll is offline
Boat: 2006 X45 8.1L
Help! Check engine Code
Hi guys. 2006 x45 with 8.1L . Was at idle when the beep alarm came on and the dash read check engine. Throttle was no responsive. could only idle. If i shut off the engine, then restarted, i could drive just fine with no beep. If i sat idle for any amount of time it would happen again. No overheating or low oil pressure. How do i read the code? can i use the same reader i use for my suburban? where would i plug it in? thank you in advance!
Old 06-16-2014, 03:08 PM
lz35zs's Avatar
lz35zs lz35zs is offline
Boat: MasterCraft X 7 2006 Indmar 5.7 MCX
I am working on a over heat issue on my 5.7mcx it is also a 2006.
MikeG sent me this link not sure if it is the same.
http://www.michiganmotorz.com/advanc..._description=1
Old 06-16-2014, 03:22 PM
06MCX15's Avatar
06MCX15 06MCX15 is offline
Boat: Mastercraft X15, 2006, MCX 5.7 liter vortex, yellow / white slider
I had a similar "Check Engine" code appear on my 2006 MCX 5.7 liter last summer. It happened only when I was manuvering the boat into a gas dock or tight spaces. My initial thought was a bad throttle position sensor (TPS), so I did some internet reading. I came across some threads that this can sometimes be caused by the MC speed control grounds. So I pulled out the switches for the MC speed control and tightenend up all of the electrical connectors. I also added di-electric grease to each terminal. Next, I took off the TPS electrical harness from the throttle mechanism and greased it up too. Finally, I just made sure the throttle lever was properly adjusted and tightened on the shaft. I have had not one problem since. I really think my problem was the ground on the MC speed control. However, I am not sure if you have this setup or perfect pass. If you have the MC speed control, start there and then test. Next grease the TPS harness and test. Finally, make sure your throttle lever is properly positioned / tightened on the shaft.
I hope this brings you the same luck I had.
Old 06-16-2014, 03:56 PM
Boat: 2006 X45 8.1L
Yes, it has the MC system. I will start there! thank you!. Do you know how to read the codes? if i can use the same code reader as my suburban?
Old 06-16-2014, 03:59 PM
06MCX15's Avatar
I dont think you can just use an OBD code reader that the auto industry uses. You need to buy a marine unit. I have never read the codes out of my system, as the only trouble I have ever had was last year. My 3 repairs fixed the problem, so I never got as far as buying a marine reader.
Old 06-16-2014, 04:04 PM
06MCX15's Avatar
Oh, and be sure to post your findings so others can benefit. I tried 3 fixes at once, so I cannot be sure which did the trick. Like I said, I think my problem was the MC speed control grounds. However I cannot be 100% certain.
Old 06-16-2014, 04:09 PM
Boat: 2006 X45 8.1L
I will definitely update you. Thanks again!
Old 06-16-2014, 10:04 PM
BG1772's Avatar
BG1772 BG1772 is offline
Boat: X-Star, 2001 5.7L LTR
Boats do not use ODB2 readers. You'll need to find somebody that has a marine code reader like rinda diacom marine.
Sent from my Nexus 7 using Tapatalk
2001 X-Star 5.7l LTR
Old 06-16-2014, 11:22 PM
Michiganmotorz.com has one as well.
Old 06-16-2014, 11:38 PM
Jeff d Jeff d is offline
Boat: 2000 230 VRS
Does the paper clip trick work on 2006s? I was able to jump 2 pins on the diagnostic port and then the check engine light would "telegraph" the codes. No code reader needed.
8.1, x-45
