Old 05-28-2014, 11:10 PM
Topp dawg Topp dawg is offline
Boat: 2003 Mastercraft X10
I do have the seal. Advance auto parts didn't have the same one so they just grabbed one off the shelf and said it was the same size. You think they will return it, I'm sure I will bend it all up removing it from the hub.
Old 05-29-2014, 11:17 AM
Boat: No Boat
They sold you the wrong part and you realized it after the install. If it matters to you I would ask for the manager and explain the issue and how the seal would not work.
You can clean the grease off the bearing and the race with parts brush and gasoline.
Tim
Old 05-29-2014, 11:40 AM
Table Rocker's Avatar
I am wondering what would happen if you added oil to a hub with greased bearings. I can't think of any reason it would be a problem, but I'm not sure I would want to be the guinea pig.
'96 ProStar 205 SD LT-1
Old 05-29-2014, 12:00 PM
mcmx2 mcmx2 is offline
Boat: 2005 TT 197 #77
I think if you changed the rear seal from a grease seal to an oil seal and found a way to seal the front side so it did not loose the oil then you would be fine.
2005 197 TT #77 LQ9
Old 05-29-2014, 02:20 PM
Advance auto parts told me they would refund my money I just need to find the right seal now. I called several places and they all just said to bring in the one that came off. I was hoping there would be some way to look it up based on trailer model info.
Old 05-29-2014, 02:56 PM
Boat: No Boat
http://www.mastercraft.com/teamtalk/...highlight=seal
Tim
Old 05-29-2014, 02:57 PM
It might be a National Seal 413470. I think your hubs are Reliable.
Old 05-29-2014, 02:58 PM
Boat: No Boat
Not sure if this is the correct seal but call them.
http://www.etrailer.com/question-69586.html
They will know what you need.
Tim
Old 05-29-2014, 03:49 PM
I think you need 2.125 I.D. The seal you bought was 2.25 I.D., other than that it was the correct seal. The 412920 is a double lipped seal with a garter spring, just too big on I.D.
Old 05-29-2014, 09:49 PM
Called them and ordered 2 seals and brake pads. They were awesome and knew what they were talking about. Brake pads were around 25 bucks for 2 sets and the seals were 22 bucks each. Thanks again for the help.
bearings, brake pads, hub, oil bath, trailer
