Old 05-27-2014, 12:01 PM
1stwave 1stwave is offline
Boat: 1996 Prostar 190
Crossed battery wires
Ok- I was in hurry and had a boat loaded with family ready to go skiing. I connected the battery and crossed the wires- plus to minus etc.. Needless to say, we didn't go boating- boneheaded!
1996 Prostar 190, nothing smoked and all of my gauges work. The engine turns over but I'm not getting ignition. I've checked the fuses at the top of the engine- all good. Battery wires functioning. Where could the problem be? I recall hearing about his before- a fried resistor in the distributor? Any help would greatly be appreciated!
SM
Old 06-02-2014, 03:39 PM
Boat: 1987 ProStar 190
I won't be much help here, but does your boat have an ECM? Those can be highly sensitive to electrical spikes.
Old 06-02-2014, 03:41 PM
I think there is a 50 or 60 amp re-settable breaker on the back of the engine.
Old 06-05-2014, 12:25 PM
Thanks. Yes- It has an ECM. I've had a mechanic look at it and he said it was the ECM. Supposedly, there are some diodes in the ECM that were damaged. I'm told that I will need a new ECM programmed by someone in California.
Old 06-05-2014, 12:43 PM
Those are a hard to find. Worthing Skier here in the UK has a number of them.
Indmar will also reflash for $45 dollars.
I found on on Ebay sent it to Indmar to test and reflash -100% working condition.
Also you have an MEFI-1 but you can also use an MEFI-2 with a little modification in the wire harness.
Old 06-11-2014, 03:40 PM
turbozinke turbozinke is offline
Boat: 2005 Mastercraft X-Star
I don't have the same boat but my ECM did go bad all the sudden. I don't think I put the battery wire on wrong, it just stopped. I had MEFIBURN.COM flash my new ECM that I got from Crate Engine Depot. MEFIBURN.COM charged me $200 though, so maybe sending it to indmar for $45 is the way to go
http://www.mastercraft.com/teamtalk/...ad.php?t=61024
Old 06-11-2014, 05:35 PM
which mefi did you get from crate engine depot?
Old 06-12-2014, 08:03 AM
Engine Nut's Avatar
Engine Nut Engine Nut is offline
The ECM does have some protection against reverse polarity but the ignition module in the distributor does not. The first things to go in a reverse polarity situation are the ignition module in the distributor and the alternator. I would make sure those are checked before replacing the ECM.
Engine Nut
Indmar Marine Engines
Power to the Sport
