Old 05-11-2014, 03:45 PM
mgs96ps mgs96ps is offline
Boat: A
LT1 belt and tensioner
Old 05-11-2014, 05:02 PM
CruisinGA's Avatar
Boat: '01 X9 330HP
Basically the only thing that wears out is the pulley bearing. Just check it for slop or roughness.
Bailey
'02 X-9
Lake Blue Ridge
Old 05-11-2014, 05:19 PM
ricford's Avatar
ricford ricford is offline
Boat: 1996 Prostar190
On my LT1 there is no spring tensioner. Loosen the alternator bracket and rotate to add tension.
Old 05-11-2014, 05:40 PM
Table Rocker's Avatar
Very strange, I have '96 LT-1 and it has the alternator fixed in position and a tensioner pulley.
As CruisinGA said, the only thing that normally wears out is the bearings in the pulley. The spring in the tensioner could break, but that would be unusual.
'96 ProStar 205 SD LT-1
Old 05-11-2014, 07:54 PM
Boat: A
Old 05-11-2014, 09:02 PM
Originally Posted by mgs96ps View Post
TR....I have the same setup but I believe that something is going om with the internals outside of the bearings. When I turn the center bolt, it seems to spin and chane angle front to back when your looking down at it.
Something is wrong, because it shouldn't wobble at all. It is either bent or loose. You can buy just the pulley. I would take my old one in to be sure, but here is one: http://www.oreillyauto.com/site/c/de...3308&ppt=C0328
Old 05-11-2014, 09:23 PM
Boat: A
Old 05-11-2014, 09:30 PM
Maybe I should just replace the whole assembly. I found it odd that the belt split into halves. Any chance you have part # for assembly?
Mine looks like this, but again I would carry my old part in. This is for a '96 Z28.
http://www.oreillyauto.com/site/c/de...mbly-automatic
Old 05-11-2014, 09:36 PM
Boat: A
Old 05-11-2014, 09:40 PM
That's the one I have. Thank you. I guess I don't understand how turning center bolt flexes the spring below...but that's probably because mine is not working correctly.
The pulley bolt won't have any impact if you are loose on the spring axis. I misread where you were getting the wobble.
