Old 07-21-2017, 02:38 PM
JP-OH's Avatar
JP-OH JP-OH is offline
Boat: 2012 x-15 5.7
Gelcoat chip
Can this be used as is for a while or will it need to be repaired ASAP to prevent the boat becoming waterlogged
50.241899, -115.857747
JP-OH's Avatar
Boat: 2012 x-15 5.7
PS I have no idea how this happened. It's on the starboard side and we never doc to that side I never hit anything that I was aware of I have no idea how it happened
Old 07-21-2017, 04:22 PM
CheeseSteak1's Avatar
CheeseSteak1 CheeseSteak1 is offline
Boat: 2009 X30 MCX / 2003 X2 MCX
I would say you hit something. Could have been in the water and didn't see it
Old 07-21-2017, 04:28 PM
kadam75's Avatar
kadam75 kadam75 is offline
Boat: Mastercraft X-20 2016 5.7L
i would say if the fiber glass is damaged (kinda looks like it is), and it will be in the water 100% of the time get it fixed ASAP. I had some hull damage that we just got fixed. We used ours till our MC dealer could get it in, but we do not leave ours in the water and when we went out we made sure to get our fun in and get off. We did not float/anchor anywhere and got in and out. so very low hours with the fiber glass exposed. Initially i did call my MC dealer, and they said i would be fine to use it short term but needed to get it fixed as soon as i could.
2016 Mastercraft X-20
2006 Mastercraft X-15 (sold)
Old 07-21-2017, 11:41 PM
blackhawk's Avatar
Boat: 2006 X15 350 MCX
I would definitely get that fixed before putting it back in the water.
We defy the mafia!
Old 07-22-2017, 02:49 AM
X2Scool X2Scool is offline
Boat: '09 Mastercraft X2
Hey John,
I'm having the same problem but mine is top side in the bow. If you find a guy let me know.
Sean
Old 07-22-2017, 05:27 AM
T-Rager T-Rager is offline
Boat: 2004 ProStar 197, MCX, Sammy Duvall
I had a fender bolt work loose on my trailer and over time it gouged through the gel coat and into the underlying fiberglass of my ProStar a few millimeters . I didn't notice the damage for quite some time because when the boat was on the trailer, the damaged area was obscured by the trailer fender.
I fretted about it for a while, but did nothing about it for 10 years. The boat was kept on the trailer, but was used two or three times per week all year around.
Before I sold the boat, I repaired the damage. In so doing, I found no ill effects from the 10-year exposure to lake water and the elements.
The gel repair kit I used worked great, but some trial and error was required to get the color match perfect.
Old 07-22-2017, 07:50 AM
bturner2 bturner2 is offline
If you don't want to get it fixed now all you really need to do is seal it up with a light coat of epoxy. Or order the color up from Spectrum and fix it yourself. Those are fairly easy chips to fix for the DYI'er.
Old 07-22-2017, 09:29 AM
jgraham37128 jgraham37128 is offline
Boat: 2016 Mastercraft X23
If it's not leaking it's fine. It's not a big chip just a small chuck and won't be expensive to repair.
Old 08-13-2017, 01:28 PM
uplandbird uplandbird is offline
Boat: 2014 X25 6.0L, Gen 2
Hit something last week at Tablerock. Not sure what, but it must have been big. I assume I need to fill this somehow before going back out.
Boat stored on a lift, not in the water.
