Old 06-10-2014, 08:03 PM
HRC HRC is offline
Boat: 2001 Prostar 205V
Floor panel removal
I have a 2001 Prostar 205v. How is the large square floor panel removed? Its the one between the back seat and the ski locker. Thx.
Sent from my XT907 using Tapatalk
Old 06-10-2014, 08:16 PM
BG1772's Avatar
BG1772 BG1772 is offline
Boat: X-Star, 2001 5.7L LTR
Yes. I have the same boat. The panel will be under the back seat, so you will need to pull up from the end by the ski locker. Mine fits in really tightly.
Sent from my Nexus 7 using Tapatalk
2001 X-Star 5.7l LTR
Old 06-10-2014, 08:51 PM
HRC HRC is offline
So use a screw driver or some other flat blade to get under the front and pry up?
Old 06-10-2014, 08:55 PM
BG1772's Avatar
Do you have a hole in the floor to access the drain plug? If yes, then you should be able to pull from there. Mine actually has a small handle in the floor. Worst case you could use a screw drive our thin pry bar. The panel is aluminum. The space between the panel and locker is fiberglass.
Old 06-10-2014, 09:07 PM
HRC HRC is offline
No hole in the floor.
Old 06-11-2014, 06:57 PM
megapea's Avatar
megapea megapea is offline
Boat: 1999 MariStar 230VRS w/ LT-1
I just worked on mine in my Maristar 230. I just removed 2 Philips head screws and pulled up from the access hole for the floor drain and bilge pump. I just can't get the whole panel out because it is so tight under the seat support. I'm going to add a floor mounted removable table and need to drill a hole for the table support and I didn't want to hit the gas tank.
