Old 07-30-2014, 09:46 AM
6gun 6gun is offline
Boat: 1990 Maristar 240 SC, 454/425hp
Exhaust Riser plug thread tap
Anyone know where I can get a "reasonably priced" thread tap to clean up the threads on the drain plugs in my exhaust risers? Tried wire brush, did some good, but they still leak a little. Don't want to force the drain plugs in and crack the risers....
Plug is 1" ... so a real tap would run around $90 for a 5 minute job....
Old 07-30-2014, 10:32 AM
Boat: No Boat
http://www.hardwareworld.com/Pipe-Ta...T-p10K8BI.aspx
Old 07-30-2014, 12:01 PM
jmhjgh jmhjgh is offline
Boat: Mastercraft,205,1996
Are you using teflon tape? Cleaning with a wire brush and teflon tape should be more than sufficient for sealing.
Old 07-30-2014, 05:08 PM
WOW! C.R. awesome find! Thanks!
JM - Yes....I either use T-Tape or Locktite Copper or Nickel Anti-Seize, which I use all around the boat and trailer...lug nuts, drain plugs, steel bolts on aluminum tower, rudder rigging, etc.
HOWEVER....
I had the boat winterized last winter by someone else and the tech left the manifold drains out after draining in a plastic bag and the untreated threads got pretty filled up with rust.
Old 07-30-2014, 05:44 PM
Table Rocker's Avatar
I don't know what size tap you need for your boat, but my boat's plugs are 3/4" NPT. The hole is about an inch, but pipe sizes are the inside diameter of the pipe that would thread in that hole.
'96 ProStar 205 SD LT-1
Old 07-31-2014, 01:02 PM
No worries Table Rocker, I plan to "measure twice, cut once" and will put a caliper on it before I buy the tap. BTW, where do you go on Table Rock? We have a place west of Shell Knob on the lake between the 22 and 23 mile marker on the main channel.
Old 08-01-2014, 10:37 AM
We are directly across the channel from the slalom course at Little Cow Creek. We are on Coney Island which is just east of the Kimberling City bridge.
Old 08-04-2014, 06:38 PM
Worthing skier's Avatar
Boat: mastercraft prostar 190 1993 & 1996
Tap size
Hi there
3/4 x 14 npt taper tap $8 on Ebay
Kevin
Old 08-26-2014, 08:58 PM
88 PS190 88 PS190 is offline
Another quicky if you have a steel plug around or a hardware store is to use a dremel with a grinding disc to cut a slot through the threads in line with the plug.
That slot acts like the slots in taps, but will act to clean them up.
Old 08-27-2014, 12:31 PM
bochnak bochnak is offline
NPT info:
http://www.engineeringtoolbox.com/np...ads-d_750.html
Maybe brush on some evaporust and skip tapping?
Mine are pretty rusty too, and don't have a lot of thread engagement.
-Matt
