StarBrite Teak Oil?
Is this product OK?
I use this product on my swim platform. Depending how bad the oxidation is, you might need to do a light sanding before applying. Or you may need to brighten/oil a couple times.
I'd use that kit but would pass on the oil. Get some linseed oil and mineral spirits 80/20 mix.
Tim "Heavy" beer is for wine drinkers that are too embarrassed to drink wine in front of their buddies. "Light" beer is a drinkin' man's beer! |
I'd skip the entire kit, and I'd pressure wash the teak. Lightly sand it if needed, then apply two coats linseed/mineral spirits with a brush. Here's a photo of what pressure washing alone can do. I lightly sanded this for 10 mins, washed again, and then applied linseed oil. Wait 24 hours for drying, and reapply. Done. Good luck! |
It's a do all kit..so if you don't need the cleaner. Make your own oil, as suggested. If you have
mold and/or mildew, Simple Green works, as a cleaner. The lightener, is basically a bleach. (Not really sure, what the chemical is.) A light sanding, makes the oil last much longer. I oil mine, twice a year. Clean it, at the end of the season. On older platforms, be careful on power washing, as the swim platform can de-laminate. ![]()
2004 Red/White/Black something or other. ![]() Formally, 1994 RED Mastercraft 205, Chevy 5.7 TBI. |
I used this product 2 years ago, following directions on the package. My platform never looked better, and I have enough product left over for 2 more applications. The sanding prep is the key.
#7
I don't have a before pic but this is after using the cleaner, then brightener, then some quick 220 and finished with one coat of 80/20.
#8
I had a platform that was awful - it had been varnished. stripped the varnish, still looked awful. Gave it a bath in a pretty strong concentration of TSP and hot water, (in the shower, with a long brush, wearing gloves) let that soak awhile - about thirty minutes, reapplying every 5 or so. Then I let it dry a few days. Gave it a light sanding, and then treated it with three coats of Boiled linseed oil/mineral spirits (75/25) over about a week.
Went from this ![]() To this: ![]() Total cost... umm, maybe 5 bucks?? And I already had everything in the shop. It takes very little oil to do it... If you've got a well equipped shop... you've probably got everything on hand...and don't have to spend a dime...just a few hours. |
#9
I do about 10 minutes of sanding with my orbital and some 60-80 grit. Any smoother than that can make for a slippery deck. Then, two coats of 75/25 linseed oil/mineral spirits, total cost is 4-5 bucks and the platform looks brand new. Lasted all season last year moored in the open sun of CO and water exposure - for 5 solid months. Just finished a quick sanding last night and about to apply coat #1. I waited a week between coats last time, not sure you have to wait that long. 2-3 days might be about right. I would never spend the money for one of those kits now that I've seen how easy, effective and cheap this system is.
#10
Don't use bleach on a teak platform. It wreaks havoc on the wood. It literally won't feel the same (almost spongy).
Previous: 1993 Prostar 205 Red 1998 Ski Nautique, PCM GT40, 310 hp, , Acme 4 blade, Perfect Pass SG/Zbox. FAQ Be kind. Have fun. |
Thread Tools | |
Display Modes | |
