Old 04-19-2014, 07:02 PM
weist1013's Avatar
weist1013 weist1013 is offline
Boat: 2001 230
Send a message via Skype™ to weist1013
2001 maristar questions shifting
Is the transmission all mechanical,hydraulic or hydrastitic? Should the boat go in gear when it is not running?
Old 04-19-2014, 07:45 PM
The prop will turn when the boat is on the trailer and in neutral most times. ... in the water the load from the water will keep it from turning.
Old 04-19-2014, 07:47 PM
weist1013's Avatar
Boat: 2001 230
Thanks mike, when on the trailer should the prop turn easy by hand?
Old 04-19-2014, 09:18 PM
Boat: 1998 Maristar 200VRS
Yes, in neutral or in gear the prop should turn by hand. If the driveline is well adjusted, it can be a one-finger turn; if not, a one- or two-handed turn isn't unheard of.
Old 04-20-2014, 07:25 AM
weist1013's Avatar
Boat: 2001 230
My shift lever is shifting fine but the boat is not going in gear. Any ideas?
Old 04-20-2014, 12:48 PM
Low transmission fluid level?
Perhaps the transmission oil cooler froze over the winter, and the fluid leaked out.
Someone pulled out the neutral knob on the shifter and it didn't pop back into place?
Old 04-20-2014, 01:52 PM
weist1013's Avatar
Boat: 2001 230
thanks frank, i will check the fluid. its a hurth transmission. wher can i find a manual for the tranny?
Old 04-20-2014, 02:01 PM
weist1013's Avatar
Boat: 2001 230
found the info! http://www.simplicity-marine.com/ZF/ZF63/Technical.htm
Old 04-20-2014, 02:23 PM
Info also in forum library . First sticky thread in general discussion will take you there.
Old 04-20-2014, 04:20 PM
weist1013's Avatar
Boat: 2001 230
I got the fluid drained and topped off with 4.2 QTS. The boat goes in gear now but tranny is squealing.? Getting nervous!!;
