Old 04-18-2014, 11:14 AM
cruiser cruiser is offline
Carb Gasket
Just pulled the boat out of storage. Started installing the carb I rebuilt over the winter. 4160. My question is there is a paper thin gasket for under the aluminum spacer and two for between the spacer and the carb. One is about .020 and the other is a very rough gasket about 3/8 thick with plastic inserts in the bolt holes. I don't remember taking that kind of gasket out last winter. Any thoughts?
1981 stars and stripes -powerslot
sand with red metalflake stripe
Old 04-18-2014, 11:44 AM
One gasket for each side of the spacer. I like the thickest gasket I can get. Seem to be less likely to have a leak from it. Two gaskets are a guaranteed leak at some point, if not right away.
Old 04-18-2014, 11:59 AM
The one gasket for the top of the spacer is 3/8 thick and the finish on it is so rough I would think by using it I would have a leak for sure. I will try to get a pic.
Old 04-18-2014, 12:00 PM
Could be you got a lousy gasket. Should be pretty smooth. Was this from a Holley Marine Kit?
Old 04-18-2014, 12:09 PM
Pics of gaskets, Like I said I don't remember cleaning off the thicker of the two. Would it be ok to just use the thin gaskets.
Old 04-18-2014, 12:11 PM
Yes they came in a holley rebuild kit.
Old 04-18-2014, 12:21 PM
abburns abburns is offline
Boat: 1990 Tristar190
I also rebuilt my carb over the winter with the holley kit but I did not get the thick gasket. I only got one of the gaskets with the numbers printed on it like you have in the picture. My understanding is I need two of those...one for each side of the metal spacer. I have some felpro gasket paper so I will just trace the existing gasket and cut it out to make the second gasket.
Old 04-18-2014, 12:45 PM
I happen to have a Holley 703-47 Marine Renew Kit sitting next to me. It has two of the nice fiber gaskets in it. There is no larger gasket with plastic inserts. I don't recall having those in a marine kit before, but I don't always pay too much attention to them when I put them on.
What part number kit do you have?
Old 04-18-2014, 01:31 PM
Holley 703-33
Old 04-18-2014, 01:48 PM
I would use the thinner gaskets. There are multiple applications per part number. You could give the guys at Holley Tech and ask them why the three gaskets. In my experience, they are all good guys and full of information. 270 781-9741
