Old 04-17-2014, 08:57 PM
funonthewater funonthewater is offline
Boat: 1989 Prostar 190 351
Couplers do not line up between transmission and drive shaft
I recently placed a used '85 PCM motor and placed my standard 1:1 transmission from the original 1989 Indmar into my 1989 Prostar 190. The motor mounts from the '89 Indmar were pretty crusty and one was bad, so I used the motor and tranny mounts from the PCM. Everything seemed to be going well, including the adjustments to line up the coupler on the drive shaft, then I ran out of adjustment on the starboard motor mount. I'm still not aligned to spec for the couplers mating together and it appears I may need to modify the mount to get everything aligned properly. Is there any adjustment in the drive shaft at all that could help me get things lined up or do I need to look at cutting away at some of the motor mount area that looks the end of a bone. This may get me the additional adjustment that I need. I can move the drive shaft back and forth a bit, which appears to give me the adjustment that I need, however I'm not sure if I'm creating an issue that will result in a vibration. Can I move the shaft to line up the couplers or should I modify the mount.
Thanks in advance for any help that you can provide.
Old 04-17-2014, 09:42 PM
Bouyhead here made a modified mount.. but the strut and shaft log govern the drive line.
Pictures would be helpful.
Old 04-17-2014, 10:47 PM
milehigh970's Avatar
milehigh970 milehigh970 is offline
Boat: 1986 skier w/ a fresh 351 and 2008 x2 w/ MCX
Did you check to make sure your driveline comes through you shaft log straight? Do your strut bushings look like they are wearing uneven?
Old 04-17-2014, 11:35 PM
Boat: 1998 Maristar 200VRS
Is it possible that the port/starboard engine mounts are slightly different lengths, and if you swap them you'll be in good shape?
Old 04-18-2014, 10:45 AM
TRBenj TRBenj is offline
Boat: 1990 Ski Nautique
How/where are you supporting the driveshaft during all of this? Is it being held in place where it is aligned in the strut (where it spins freely)? Or are you letting it sag under its own weight? If the latter, you need to start over.
No, you cannot really change how/where the strut and log are installed in the boat without starting a major project (and that would be back asswards). Alignment starts from the strut forward, meaning the shaft is aligned to the log first (this should already be the case unless the strut is tweaked or it was previously screwed up by a previous owner or the factory). Where the motor installs is a result of where the shaft is, not the other way around.
Which way did you run out of adjustment? Left/right, or up/down? Moving the engine forwards or backwards a little can help with the up/down problem. So can placing additional blocks (aluminum, etc) under the mounts if it needs to go up.
Old 04-18-2014, 03:01 PM
The shaft log, rubber coupling and shaft running to the transmission are not supported. Also, I am out of adjustment from left to right, up and down I am fine at this point. I can take some pictures next week when I have access to the boat again.
Old 04-18-2014, 05:54 PM
You should be able to shift motor/trans left right . Adjustment must be more than .003 top to bottom left right and stay parallel when turning. Shaft should turn easily by hand.
Old 04-21-2014, 07:25 PM
A left/right alignment issue may indicate a bent strut. Better pop under the boat and take a close look. A small framing square and a tape measure may help you spot a bend that can be difficult to see with the naked eye.
Old 05-02-2014, 10:47 AM
Below are some pictures of what I am looking at. The engine is out of adjustment without modifying the mounts.
Name:  boat pic 1.JPG
Name:  boat pic 2.JPG
Name:  boat pic 3.jpg
Old 05-02-2014, 11:56 AM
I assume the point you are comparing to is where the shaft spins freely in the strut?
If so, then I still suggest:
