Old 04-15-2014, 09:54 PM
morgan320i morgan320i is offline
Boat: 94 prostar 190 lt1
Oil pressure question
What's an average hot oil pressure for my 94 prostar 190 with the lt1 734 hours
Hot I'm running 18 psi at 6-700 rpm idle and 40-45 psi at 30-35 cruise 160-165 hot temp
Boat runs perfect but are these good numbers
Old 04-15-2014, 10:34 PM
ncsucarjock88 ncsucarjock88 is offline
Boat: 87 PS190, powerslot
Matches what I see out of my '87 with a 351w.
Dunno if it's good or bad. But in all my years with engines... if it's got more than 5psi at idle, and comes up to 40psi under load - you're golden. Some engines run slightly different numbers... but I'd say you're in the ball park.
Old 04-15-2014, 10:38 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
Indmar Spec.
Oil Pressure at Idle 4PSI (41kPa) Minimum - Hot
Oil Pressure at 2000 RPM 18 PSI (124 kPa) Minimum - Hot
Sounds like your just fine...
/spôrk/
Old 04-16-2014, 01:29 AM
I'm paranoid, I have a 6.0 ford powerstroke that runs perfect but I'm waiting for it to blow up haha
