  #41
Old 04-10-2014, 10:27 AM
jdhart73's Avatar
jdhart73 jdhart73 is offline
Boat: 2013 X30
Guess I'm not tracking. A traditional thru hull is like this correct?
Only way I see to add additional ports is with a T after the gate valve.
Old 04-10-2014, 10:58 AM
FourFourty's Avatar
Should look like this...... Notice how it has the second port added to the top? You can do this to the existing thru hull that only has the lower port on it. (KGB thru hull)
Old 04-10-2014, 11:03 AM
jdhart73's Avatar
Boat: 2013 X30
But I would need 3 ports on one correct? Running an additional pump to each side.
Can you stack 3?
Old 04-10-2014, 11:07 AM
FourFourty's Avatar
That's up to you. On my XStar, I added the top port, and then T'd that to the two added pumps. It seemed to work well. On my 30, I am only adding one pump, so I didn't T any of it. I do believe you can make this style thru-hull into a 3 port without flow issues.
I suppose that if you are adding 2 pumps, the most "Ideal" setup would be to add 1 thru-hull, like the one pictured, and use those two ports.
Old 04-10-2014, 11:30 AM
Nick911's Avatar
Nick911 Nick911 is offline
Some good info in this thread. It should almost be renamed.
jdhart73's Avatar
Boat: 2013 X30
I've never seen that kind of thru hull fitting before so I'm not familiar with the installation.
It certainly looks like it has a bigger footprint and profile than the standard brass mushroom.
I would probably just stack one like you mention and T off of it.
Old 04-10-2014, 11:35 AM
FourFourty's Avatar
The center hole is quite a bit bigger than 1". It definitely allows for really good flow to the 1" ports. It is a nice design that they switched to.
Old 04-10-2014, 11:46 AM
jdhart73's Avatar
Boat: 2013 X30
Thanks! Looking into this, could save me some drilling which would be nice!
Old 04-10-2014, 11:48 AM
bjen bjen is offline
Boat: looking-2003 X2-sold-
Interesting
- can that thru hull fitting be used and retrofitted to avoid drilling 2 more holes to run dedicated lines to my old gen X2 with the manifold? I like the idea of enlarging the existing hole better than drilling new ones like I was planning.
Old 04-10-2014, 12:25 PM
DHPRO's Avatar
DHPRO DHPRO is offline
Boat: 2014 Gen II X30 SS
Where do u live...Im bringin my boat to u! This is wayyyy over my head.
