Old 03-23-2014, 10:52 PM
andersonmc andersonmc is offline
Boat: 2001 X star
Wiring question
just replaced all my lights with LED's and everything works perfect. Except for my reverse lights. They never worked when I bought the trailer. Pretty sure the bulbs were toast as stuff was loose inside on the old fixtures. I'm pretty sure they turned on right when I put the truck in reverse but went out immediately. Not positive but I could of swore I saw them on. Checked plugs and ground. Where should I start?
Old 03-23-2014, 10:57 PM
Sounds like a wiring problem that is shorting out the circuit breaker for the back up light circuit. Have you checked for battery voltage at the connector with the trailer unplugged?
Old 03-23-2014, 11:22 PM
Rossterman's Avatar
Boat: 2001 prostar 205V
May want to check your plug on the truck side. Very few trailers have backups and many time PO leaves this disconnected. You should have a flat 5 plug.
Old 03-24-2014, 11:11 AM
Boat: 2001 X star
I know my tuck is ok. I have another trailer that I use that has back up lights and they work fine. So I know its somewhere on the trailer. Should I check the plug to see if its getting power at the light? I have a feeling its shorting out somewhere on the trailer.
Old 03-24-2014, 11:33 AM
dt37803's Avatar
dt37803 dt37803 is offline
Boat: 2014 X2 5.7 Pro Surf Gen 2
If they are led the positive and negative May be reversed
Old 03-24-2014, 12:04 PM
I would disconnect both back-up lights and connect to tow vehicle to see if you have a wiring harness short to ground. Then plug in each light to see what happens.
Old 03-24-2014, 04:38 PM
Boat: 2001 X star
Just looked at flat plug. 6 wires are connected but the 2 blue are not. There is also one blue wire coming from trailer that looks to been cut.
Old 03-24-2014, 05:02 PM
Kweisner's Avatar
Kweisner Kweisner is offline
Boat: 2007 Prostar 197
I think blue is the standard color for electronic brake control, but who knows how any individual trailer's been wired (or rewired)! Red is normally for the backup light.
"This one goes to eleven." 2007 ProStar 197 TT w/MCX and Powerslot.
Old 03-26-2014, 11:12 AM
Boat: 2001 X star
Well the two blue wires were aux which Wesbar says is usually for back up lights. Found the 2 blue wires way up in tongue that someone had cut. Original owner truck must have not been set up. They work great now. Thanks
Old 03-26-2014, 11:19 AM
Well played.
