Old 03-14-2014, 02:34 PM
CC2MC's Avatar
CC2MC CC2MC is offline
Boat: 2005 x-10
Fuel Filter Predator engine
I am wondering if the only filter for this is located inside the fuel tank, attached to the fuel pump. At the end of last season, I had issues getting over about 3/4 throttle without the engine surging badly. I had a similar issue with my 94 PS 205 and cleaned the screen at the base of the fuel pump and we were back in business. Is there something similar I could try with this type of pump? I have new plugs, but haven't installed them yet. I will probably try those first but I would like to know what I may potentially have to get into.
BTW, I rarely even go over about 25mph, as we wakeboard and sky ski so it is generally a non issue, but I would like to get it fixed.
Old 03-19-2014, 09:21 PM
CC2MC's Avatar
Boat: 2005 x-10
I followed the fuel line and didn't see any in line filter. I am guessing the only filter is within the pump itself.
Old 03-19-2014, 09:28 PM
Footin's Avatar
Footin Footin is offline
Boat: 2007 Maristar 200VRS X2
Have you changed the filter in the tank?
OH-IO!
Old 03-19-2014, 09:53 PM
KnoxX2's Avatar
KnoxX2 KnoxX2 is offline
Boat: 2014 MasterCraft X30
As far as I know you are correct. The only filter is the one on the bottom of the pump. I was told at $15 it should be changed each year and it will save the life of the pump.
Old 03-19-2014, 09:58 PM
Footin's Avatar
Here is the filter in the tank: http://www.skidim.com/prodinfo.asp?number=155101
OH-IO!
Old 03-19-2014, 10:02 PM
KnoxX2's Avatar
OK so I may have been a little off on the price or they have doubled in the last 4 years.
Old 03-20-2014, 12:38 PM
CC2MC's Avatar
Boat: 2005 x-10
I have not changed the filter as I have only owned the boat since the end of last year. I am fairly certain that the PO did not either. Thanks for the link. From what I read, the actual filter does not restrict that much fuel flow. Could this older filter be a potential reason for the higher RPM surges? I will be putting the boat in the water in a week and replacing the spark plugs after the initial run. I am hoping that will fix the issue. A mechanic told me that it could be moisture getting into the distributor, but I am not sure how to test that one without replacing it.
Old 03-20-2014, 05:14 PM
Footin's Avatar
Surging sounds like a perfect pass problem, I don't think the filter will help with that.
It is recommended to replace the filter every year.
OH-IO!
Old 03-20-2014, 11:32 PM
CC2MC's Avatar
Boat: 2005 x-10
It is not PP. The PP is not engaged when it happens. It is only past 3/4 throttle.
Old 03-21-2014, 01:39 AM
Kevin@MWMC's Avatar
[email protected] Kevin@MWMC is offline
Same price as SkiDim but you get a New Filter & a New Gasket.
http://www.waterskis.com/155101-and-...ump_filter.htm
Sent from my iPhone 5s using Tapatalk
