Old 04-29-2014, 09:23 AM
1994+ T-stats - inline fuel pums TBI/MPI - warm hard start
I had a great conversation with Vince from SKIDIM regarding the 142/143 and 160 T-stats.
There have been a number of threads discussing hard warm restarts after installing a 160 t-stat. I also had the same problem.
What I did find out is the when run is that the inline pump fuel system would suffer from vapor lock when an engine would heat soak to 175-180. And yes it's a vapor lock - the inline pumps can't push vapor. There was no way to send mach vapor back to tank on the inline TBI pumps even thought the bottom of pump had nipples on bottom of pump. Top of pump only has one nipple.
PCM came up with a patented solution prior to USCG allowed boat manufacturers to put fuel pumps in the gas tank. PCM made an extrernal fuel filter with a high pressure pump inside it.
MC was the first to gain approval to get the in tank fuel pumps which had a vapor return to tank which solved the problem. (In tank fuel problem - another thread)
The ECT was / is not the problem - hence why the motors started cold and ran well with 160 degree t-stats. I asked if a bad ECT could cause this - Vince said so since PCM engines also the same symptoms and developed another solution prior to in tank pumps.
I run on the Illinois and never want to be in the way in any of the barges that travel the river..
It's too bad because the motors do run better with the 160 t-stat.
SKIDIM will no longer be recommending the 160 t-stat for motors for TBI with inline pumps for Indmar.
My MCOCD would not let me put this away - so I called and asked Vince.. I hope this this helps.
Old 04-29-2014, 04:30 PM
André's Avatar
André André is offline
Boat: Prostar 190 1994
Very interresting,Thanks!
So i should use a 143 on my 94 TBI?
Any crossover from NAPA?
Keep skiing!!!
Old 04-29-2014, 05:56 PM
MC205's Avatar
MC205 MC205 is offline
Boat: 1996 PS 205
I have what some refer to as ADDMCOCD in that I can't remember what t-stat I currently run. I know at one time I had the 160, but I think I switched to the 143.........I think!! Is there a way to tell???
-Aaron
RED 1996 Prostar 205
Indmar 350 TBI
Acme 541
PerfectPass Stargazer Wakeboard Edition
Old 04-29-2014, 05:59 PM
Not sure the cross reference - but it needs to be drilled for bypass flow.
Old 04-29-2014, 06:02 PM
ADDMCOCD - lol that's stage 2 MCOCD lol... the temp should stamped into.
I recommend buying the stat from SKIDIM - or someone needs to tell me where to drill the hole in the t-stat.
Old 04-29-2014, 06:19 PM
bret's Avatar
bret bret is offline
Boat: Prostar 190, 1993, Anniversary Limited.
What temp t-stat went in originally? Was there a change later in 94 production; reason I ask is my boat hardly EVER runs over 140, mostly in the 130 range. Went out the other day and it didn't make over 125, of course the water is 65. Just curious
Old 04-29-2014, 06:26 PM
Manual says 142 for TBI. 142 and 160 on LT-1
Old 04-29-2014, 06:37 PM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
I spoke to Indmar about what the original T-stat was in my '97 TBI. As stated above 142 is what it came with and what they recommend.
Old 04-29-2014, 07:04 PM
Spork's Avatar
Spork Spork is offline
Boat: Sporkcraft
The 1/16" hole would be drilled at the 12 o clock position.
/spôrk/
Old 04-29-2014, 07:06 PM
got a picture?
